Thread: What does the acronym ORP stand for?
    19,500gal, Gunite, Pebbletec, Chlorine, PCC2000 cleaner, Stenner Chlorine Pump, MegaCatch Mosquito Trap
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: What does the acronym ORP stand for?
    Oxygen Reduction Potential.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Mar 2007
    San Rafael, CA USA
    12,082
    Actually, it's oxidation-reduction potential and is a rough measure of the quantity of oxidizers in a pool and since chlorine is usually the strongest oxidizer, it's a proxy for the amount of active chlorine in the pool (not FC, when CYA is present, but more proportional to the FC/CYA ratio though also pH dependent).
    Oct 2012
    604
    Actually it is known as oxidation / reduction potential or redox potential. It is a measure of the tendency of a chemical species to acquire electrons and thereby be reduced. But let us not get technical here.
