Thread: Hoses for solar panels? What are they called?.
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    So we were able to get one solar panel going. What a nightmare this is turning into. What is the type of hose called that does not have the hard plastic thing on the ends. Regular pool hoses have that and you can't clamp them onto the solar pipe. The only one I can find is the one that attaches the vacuum to the skimmer on the intex. I need two hoses about 25 ft each and don't know what they're called. They're not pool hoses. Grrr they should tell you you need weird stuff when they describe them if anyone knows the name for these I'd appreciate it. Off to depot in the am and would like to not sound stupid. Need the ones that don't spiral all the way to the end and have the molded flat area that the clamp sits on...but not the hard adapter end things. Ugh!!
    24' Sharkline Matrix. Coral Reef Liner. Clearwater II Cartridge Filter. Saltron Retro Salt WaterGenerator. 4x20 Ecosaver Solar Panels, Rover Jr. robot vac. Fiberglass Steps and Lifesaver pool fence/gate.
    Previous pool: 9x18 intex with salt water generator and vinylworks 5x10 deck.
    22,553
    Re: Hoses for solar panels? What are they called?.
    Did you figure out what you needed?
    Sorry for just seeing this.
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    No problem. I went in sounding dumb . It's called sump pump hose. Ten bucks for 25 ft. Gonna get it Hooke up tonight! Thanks a bunch!!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Just remember sump pump hose is not designed to be pressurized, so you will need to make sure you bypass the majority of the flow from you pool pump around the solar panel so the hose does not explode.
