Thread: Pump not sucking water and not priming?
    I have hayward catridge filter pump system.
    The motor kicks on and runs I can heard the sound but its not sucking water to the filter.
    The water level is good and no debris in the skimmer basket.
    After googling i thought the Impeller was stuck with debris, but it moves spin easily with my hand. I took a screw driver and still try to clean if something is stuck, but nothing.
    Do i have to remove the motor and see for debris? or just replace the impeller or the ceramic drive shaft? or something else is going on.
    please suggest?
    30,304
    Re: Pump not sucking water and not priming?
    Most likely is that You have a suction side air leak. Somewhere between the pump and the skimmer(s), air is being sucked into the system. Find that leak and your issues will be solved.
    thanks how do i search for the air leak? since i don't see any bubbles in the skimmer
    4knights's Avatar
    NE Kansas
    419
    First thing I would check is water level in skimmer, then ALL your unions from suction(main drain/skimmer) piping and you pump basket lid o ring. If you took them apart for the winter and forgot to lube them you could be sucking air.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    ok removed the pump and the Impeller just fall out from the motor
    my seal is stuck on the motor no wonder impeller just fall of, can i remove the seal without opening the back of motor?
