Results 1 to 16 of 16
Thread: Shame on me. Shame, Shame, Shame
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    After a wonder first season using the BBB method, I failed as a BBB member during the off season. My pool cover blew off and I didn't replace it. Now I have a green awful mess. I have an 24ft x 4.5 ft. above ground. I know the process to turn it back but I am wondering if it would not be less expensive to drain it. But I have a liner and I am worrying about liner shrinkage. Any suggestions?
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Re: Shame on me. Shame, Shame, Shame
    Draining the pool is very likely to damage the liner.
    Cleaning up after only one winter is not usually all that big of a deal. Get your levels right, remove all debris beforehand, and follow the instructions in Pool School and shocking will be over quickly. Algae dies easily when the water is coldish.
    Aug 2011
    Virginia Beach
    295
    Agreed. I just went through this, albeit with a smaller pool. The issues would be the same though- uncovered & neglected over the winter. It wasn't as bad as I was expecting to get it back again. I have no idea what your cost for water is, but to fill mine last year raised the water bill $200 vs $50 in chlorine to clear it up. Either way, the pool still needed to be cleaned & scrubbed.
    You used the BBB method last year so you likely have an understanding of what happened and what needs to happen next. Why risk the liner? Test your CYA, look up your shock level, and get the chlorine flowing!(and scooping, and brushing, and retesting...)
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Well my pool is well on it's way to become crystal clear again. My husband doubted that I would be able to clear the pool quickly this year. He remembers the time and effort I spent last year, prior to finding this website. It has truly been a lifesaver. Forever a fan!!!!!
    Installed May 2011
    BBB method
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,013
    Quote Originally Posted by poolmama67
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    different angle of the pool
    Filtering 24/7 and waiting for it to clear up.
    Installed May 2011
    BBB method
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    You are on track !
    Sent via Tapatalk...
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Dang that was GREEN!!!!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    How's this for great results!!!
    Installed May 2011
    BBB method
    Richard320's Avatar
    Jan 2010
    19,013
    Bookmarked.
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    I love this site!!!!!!!!!!!!!!!!!!!!!!
    Installed May 2011
    BBB method
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
    It happened to me too...we had some warm enough days in Feb/March for algae to take hold. I bleached it to kill the algae and had to vacuum to waste to get the dead algae out. I still have another run to go at it, but that is the best way after you screw up.
    Sep 2009
    Greentown, IN
    914
    Looks like you're well on your way. That was almost fluorescent green!
    I'm dealing with algae at opening the first time this year myself. We opened the pool too late this year and the cover looks to have been leaking some nasty water through it. On top of that, we lost some of the debris on the top of the pool cover into the pool when we were removing it... Yucko!!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Well I have to say....I just came in from my nightly visit to check my levels....And I am tickled. Three days with CC-0 and FC-4 to 5
    I LOVE TFP!!!!!!!!!!!!!!!!!!!!!!!
    Installed May 2011
    BBB method
    Excellent job! I was/am in the same boat - going from green to clear as we speak!
    Good luck!
    16x32 in-ground vinyl-lined pool
    Hayward 1.5 hp 2 speed pump
    Hayward 24" Pro-Series High rate sand filter
    Pentair Intellichlor IC-40 SWG, Pentair multi-color LED light.
    TF-100 Test Kit (the best test kit EVER!!!! If you don't have one, get one NOW!)
