Results 1 to 13 of 13
Thread: Paver deck base?
    Paver deck base?
    In various quotes for paver deck around gunite pool, some vendors use crushed stone base and some use crushed concrete base. Any problem with the crushed concrete? I want to make sure it drains well to resist any freeze/thaw issues in the winter.
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    Re: Paver deck base?
    Stone or concrete shouldn't matter. Once everything is crushed to the correct grade for a paver base they are very similar.
    I have never seen the crushed concrete... my concerns was that it was more fines than chunks, and that it would not drain as well and give me issues in the winter. I saw some threads where people said their paver installer dumped a load of what looked almost like dirt and called it crushed concrete... got me concerned.
    Clarksville, TN
    126
    I am installing pavers around my pool now. I used crush and run which is a mix of fines and 3/4 and smaller stone. You have to have the fines in order to create a tightly compacted flat base for the sand. The deck will have to have the correct grade away from the pool just like poured concrete because after the polymeric sand is compacted in and set up you wont get much drainage thru the pavers. In other words most of the water will runoff like any other solid material therefore the drainage underneath may not be as concerning. Check out the belgard website, I think they have some details about installation.
    34,000 gal., 20x40 Roman, IG Steel/Vinyl, 500# Hayward Sand Filter, 2HP Ecostar-VS, Savi Note LEDs, Autopilot Digital 220 SWG
    The belgard dealer here told me to use 4 inch of crushed stone. I will be doing my pavers also, wondering if I need to slope away from the pool and use some type of french drain or not. I have 30 days to read up and learn more.
    15,200 Gal, 15*30 IG Fiberglass Lesure Pools, Elegance. SD80, 1.5 HP 2 speed with SWG
    30,401
    NOT sloping away from the pool is a recipe for disaster. Planning good run-off and drainage and then VERY careful sitework (to set the grade) is absolutely essential.
    Clarksville, TN
    126
    I am not sure if you can see well in these pics, but I used NDS Mini-channel drain. Kinda pricey, but it allows you to take off the grates to clean out drain if necessary. I have all areas sloping to drains or otherwise away from pool. My advice would be spend 80% of time on base prep and 20% on actual paver install and use a laser transit.
    Purchased 30 feet of the NDS Mini Channel Drain today for my install. Thanks for the advice, well made product.
    Clarksville, TN
    126
    Good luck! Lets see some pics!
    Jun 2014
    SoCal, Ca
    80
    Quote Originally Posted by janthony View Post
    What kind of pavers are these?
    Apr 2014
    Stony Brook, NY
    159
    Very nice! I really dont think you needed the drain though. The sand and gravel base is a natural drain. We do patios here with almost NO slope and never had an issue with water runoff. Looks great though!
    I also did the mini drain from NDS. The slope from the pool leads directly to my patio and I did not want water coming in through my patio doors. We get heavy rains during hurricane season. Compacted Caliche base and sand bed on top of Caliche
    Sep 2013
    Nashville, TN
    379
    The guys I used to install prefer to is a dust or 1/4 down for final paver base on top the the crush n run and 3/4 down, he said for our area and travertine pavers he has seen the best results with this base layout.
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
