Results 1 to 7 of 7
Thread: still light blue and cloudy
    can't get rid of cloudy water --see readings
    fac 10
    tac 10
    ch 250
    cya 60
    ta 80
    ph 7.4
    tds 500
    pho 0
    38000 gal inground - 1.5 hp hayward superpump 300lb sandfilter-k-2006 test kit-diving board-slide-10' x 15' tiki bar-outdoor living room
    38,471
    Re: still light blue and cloudy
    How long have you been running the pump 24/7? What is the pressure? What is the normal clean pressure?
    Did you have algae? Because your FC is not up at shock level.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Those look like pool store readings...
    In your older threads, you mentioned that you have a K-2006, and the CYA didn't even reach the marks, which puts it well over 100. How did CYA drop to 60? Have you been draining? And why are you not trusting your own test results?
    yea i was not sure of my readings so i went to leslies and had them run the test---my test was off the chart-i don't know if my test equiptment is old or what --i assume that leslies is pretty acurate--the cya was a big issue -since i would have to drain 20,000 gal of water to bring it down
    38,471
    I think your assumption is flawed, CYA is historically the test that the pool stores are the worst at. Trust your own.
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, many of us have btdt. But, it is best to always trust your own testing over a pool store.
    I suggest that you try re-doing the CYA test using a 50/50 mix of pool and tap water, then double the test result ... that will allow you to maybe get a better estimate, especially if it is > 100ppm. And, as you said, the CYA is a big issue and you need to get a confident test result.
    Here's a link to the Extended CYA Test Instructions. extended-test-kit-directions-t25081.html#p206397
    It might help to reread it just to make sure you are standing with your back to the sun, etc, etc There is also a link to Taylor Technologies under the notes section that has a pictorial review of the dot disappearing in the tube. That has helped lots and lots of us!
    You're done SLAMing when:
    Aug 2011
    Virginia Beach
    295
    I've been using my T100 & trusting the pool calculator. These things work together like magic. I punch in my results, I add what it recommends, and the pool does what's expected- even with last years reagents that were stored on top of a refrigerator in the kitchen. The local pool store didn't have much credibility with me before. 2 weeks ago they tried to sell me a bag of dichlor that "didn't have stabilizer in it". That destroyed any credibility they had with me.I'll still buy parts & liquid there, but that's about it.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
