Thread: Will clarifier give you an inaccurate CYA reading?
    I used Super Blue clarifier in my pool 24 hours ago. I checked my CYA level today and it is less than 30. (Using Taylor K-1005 Test Kit)
    Will clarifier give you and inaccurate CYA reading? If so, when should I test CYA again for an accurate reading?
    1 week ago, CYA was 43. I have not added any fresh water.
    My pool is concrete and approx 15,000 gals.
    Concrete inground pool in Texas
    approximately 15,000 gals
    Re: Will clarifier give you an inaccurate CYA reading?
    Clarifier does not usually have a detectable effect. Keep in mind that the CYA test is a little tricky to do and is very sensitive to lighting. The test is designed to be done in bright indirect sunlight. Doing the test indoors or in cloudy weather will result in lower than actual readings.
    38,507
    Wait, wouldn't lower lighting result in higher CYA readings with a lower water level in the tube obscuring the dot due to less light? I don't know why this always seems to confuse me.
    4knights's Avatar
    NE Kansas
    419
    Does it make a difference with type of lighting when you use the magic stir w built in light?
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    38,507
    The CYA test does not use the Speedstir.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    4knights's Avatar
    NE Kansas
    419
    Thanks, I haven't done it but once, and that was last summer when I put the pool in.
