Thread: raise ta today?
    raise ta today?
    numbers today
    fc 5.5
    ph 7.5
    ta 60
    ch 300
    cya 70
    temp 80 degrees.
    based on above add some baking soda today, I did add MA yesterday t bring down the ph which it did.
    Thanks again.
    13000 in ground Wet Edge Satin Tahitian Blue, Pentair VS pump, Hayward DE4820, Hayward Vac, Pentair SWG IC 40, Pentair Intellibrite 5G, Intellibrite Controller,
    TF-100 Test Kit, Seminole, West Central Florida
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: raise ta today?
    Personally, I wouldn't bother. CSI is okay, and with a SWG, 60 is right at the lower end of recommended level in poolcalculator
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Re: raise ta today?
    Quote Originally Posted by roth79
    numbers today
    fc 5.5
    ph 7.5
    ta 60
    ch 300
    cya 70
    temp 80 degrees.
    Thanks again.
    Based on your numbers... I would set the smoker at 225, grab a few of your favorite craft brews and then take a nice relaxing swim!!
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
