Thread: Mustard Algae Treatment
    Feb 2011
    Cincinnati, Ohio
    106
    I've got a question. When we had our pool closed last year I believe there was some mustard algae in it that I had been fighting for a month or so. I am therefore assuming that I will be fighting it when we open our pool.
    My question is should I go ahead and open it up like a month before I normally would to give myself a month to get it all killed off to make sure that I don't cut into our swimming time? Also, do I need to remove both LED lights and clean behind them?
    I just want to make sure I don't cause a loss of swimming time by waiting to start fighting this if it is indeed MA.
    Thanks.
    18 x 36 IG Vinyl Liner 28K Gallons
    Pentair Intelliflo VS+SVRS, Pentair CC + 420 Cartridge Filter, Easytouch CP with IC40 SWG
    2" Suction and Return Lines - 2 skimmers, 6 returns
    Dolphin Diagnostic Advantage Robot
    Re: Mustard Algae Treatment
    Dealing with it now will make things easier. Algae grows more slowly when the water is cold and thus is a little easier to kill.
    You will want to look behind the lights if they have wet niches. No need if they seal the pipe they are in (which is quite unlikely).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    A month might be overkill, but, yes, get a jump on it. And remove and scrub anything that you can. Toss pool toys and tools into the pool to soak while it's at shock level. Your SWG probably won;t work below a certain temperature, so keep that in mind. Also remember to turn it off during the overnight test. Instructions for the shock process are in Pool School.
    Feb 2011
    Cincinnati, Ohio
    106
    Do I need any other chemicals besides the bleach I will use? A pool store tried to sell me algeacide and another chemical they said was specifically for MA. If so what other chemicals do I need?
    Aside from getting all of your other levels to their ideal balance before you start shocking, no you just need chlorine.
    Feb 2011
    Cincinnati, Ohio
    106
    Thanks everyone.
