Results 1 to 12 of 12
Thread: help! lost pressure
    help! lost pressure
    Everything was working fine and then this morning i lost pressure. Tried releasing the pressure from the cartridge filter, removed the lid and cleaned the skimmer and the reassembled and tried to build pressure again. It will get up to normal pressure and the suddenly release. Where do i start to troubleshoot??
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: help! lost pressure
    I'd look for a stuck skimmer weir (flapper) and/or low water level. Either one can cause the pump to suck air instead of water.
    30,403
    I agree with Richard320. I think you are sucking air from the skimmer.
    22,543
    Is the water level in the pool low? That will cause it too.
    well, the water was not particularly low, it was covering the skimmer a little less then half way up, i added enough to get it to halfway and got my pressure back. I dont see why that would be such a big problem but I am forever grateful for the replies and I thank you folks for the help. This board is awesome.
    22,543
    Glad it was that easy.
    When the water gets low in the skimmer it causes the skimmer to create a vortex due to the speed that the water is moving and sucks in air and that causes the pump to lose pressure.
    Spoke too fast. It runs for a couple hours at normal pressure and then, poof! Drops to zero. What the heck?
    22,543
    Check the skimmer and see if it's creating a vortex. If it is then it's probably the weir like Richard said. It should swing freely in the mouth of the skimmer. If it sticks or hangs even a little it will cause the pump to sucks in air.
    Hmm, dont have a weir. Pool was here when i bought the house last winter and it never had a weir.
    22,543
    Are there tabs where a weir should go?
    Check for the vortex anyway.
    Dave J, I think you are totally right about this. I stuck my arm in the skimmer to feel around for some mounting holes for the weir door. During that process I managed to create a wave that denied the skimmer some water for a second and I saw this vortex of which you speak. Lo and behold, the pressure released just then. So, I think I really need a weir door and to keep the water full. Everyone who has repsonded had the proper instinct, which is amazing to me.
    30,403
    Most of the responders here hold diplomas from the University of Been There Done That.
