Thread: Jandy O ring broke ?
    Hey guys, my jandy o ring broke, pool stores closed today so I tried to just put the old one back on and limp until Monday ! I got the old o ring back on but now I can't get the pump to prime, is the o ring probably the cause of the of the pump not priming or do I need to look elsewhere ? Thanks
    Re: Jandy O ring broke ?
    It is very difficult to get a pump to prime when the lid isn't sealing correctly. Even a small gap in the o-ring will let lots of air in and prevent priming. Try again when you have a replacement o-ring.
    22,548
    If the old o-ring isn't broken and you have some pool lube, you can try putting lots of lube on it and see if it'll seal good enough.
    Qwaxalot's Avatar
    Jun 2012
    439
    Shave a little of the o-ring on either side of the break. Superglue the ends together. You might get lucky
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
