Thread: Clorox through auto puck chlorinator?
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I have an unused puck auto chlorinator. Just wondering if you can gravity feed a 10-15 gallon drum of Clorox into the existing cavity? Can you get a low enough flow rate with the existing valve? I know you can pump into this, but I would think gravity might do it....
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Re: Clorox through auto puck chlorinator?
    No, it won't work, there is also an explosion risk if the feeder was ever used with trichlor tablets.
    You can build a feeder that runs off of pump suction losing irrigation flow control buttons. There is a long running topic somewhere in the chemical automation area about that.
