Thread: Absorbic acid treatment
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    I did a absorbic acid treatment to remove brown stains . (5 lbs.)
    We have never had them in 30 years.
    Pool looks like new , using jacks magic purple stuff. (3 bottles at first than 1 a week)
    I need to drain my pool next weekend becuse my CYA is over 100 due to adding way too much stablizer. At the same time i will install some color splash 3g lights i have ordered.
    Question : Will my sequestered metal all be gone after the drain and rinse down with the hose.
    Or do i need to scrub the surface ?? The surface is pure white now.
    And bringing the chemicals back up with new water , tabs and powder shock until good levels for my SWG to take over ??? Or should i use liquid shock from home depot ?? Or bleach ??
    Thanks....
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Re: Absorbic acid treatment
    There is no need to scrub the surface.
    There is some chance there will be new metals in the fill water, assuming that doesn't happen, then yes the metals will be gone.
    The ideal chemicals to use with a fresh fill depend on your starting levels. Test the TA and CH levels of your fill water to get an idea of what to expect. You will want to raise the CYA level a great deal, as a fresh fill never has any CYA.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Got it !!! Thats a good idea to test fill water.
    I just took my light out and it's in bad shape no leaks but the socket is coming apart it needs to be removed and replaced, it was original vintage 1983 !!! Anybody know where i can get 2 lights that fit in a Anthony model 30 hole !!!
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Fill water test
    0 chlorine
    Ph= 8.2-8.5
    Cya =0
    Ta=80
    So it looks likes i need to add chlorine
    Bring down the ph
    And get 60-80 cya
    Pool calculater says to add acid 54 oz
    And triclor
    And stabalizer
    Does the order matter ?
    Sean Hannon
    Start working on the PH as soon as the pool is full and the pump running. Start adding chlorine the first evening. CYA can be anytime the first or second day.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Thanks !!,
    Sean Hannon
