Results 1 to 11 of 11
Thread: question on raising Ph
    May 2008
    Jackson, NJ
    38
    My pool water is clear the chorline numbers are fine. The pool is 18 ft round. The water volume is 7600 gallons. The PH is at 6.2. I want to raise it of course. I have put in the chemical PH raiser the that came with the pool. That has not raised the ph level. I read here you can add Borax to raise the PH balance. I stopped at WALMAT and bought a box. My question is how much should I put in to raise the PH to proper levels. We have had a lot of rain here in NJ where I live in the past two weeks.
    AGP Vinly Liner 18 Ft Round
    Proline Cartridge Filter
    7600 gallons
    30,421
    Well, 7 lbs of Borax (roughly) would raise your pH from 6.2 to 7.5 BUT how did you get that reading of 6.2?
    Most pool water tests do not go below 6.8.
    I would not put that much borax in my pool until I had confirmed that pH from another source.
    The amount of borax you need to add depends quite a bit on your TA. If your PH is really 6.2, it should be safe to add one whole box. Give it a few hours to circulate, and then test again to see where you have gotten to. If you post a full set of test numbers we can give you a more accurate estimate.
    May 2008
    Jackson, NJ
    38
    sorry typo
    yes sorry typo 6.8 is the reading. thanks
    7600 gallons
    If PH is 6.8, I would try about 2 cups of borax and see what that does. As before, without knowing the TA the effect might be quite different than what you expect.
    May 2008
    Jackson, NJ
    38
    what to do next?
    i ended up putting in six cups of borax, put in two and tested really no change then added four more the next day this has put it at 7.2, Should I add more or just leave it for now?
    7600 gallons
    If you are using chlorine tablets or pucks you should raise your PH to 7.6. Otherwise just leave it where it is.
    May 2008
    Jackson, NJ
    38
    Thanks
    Yes I am using chorline pucks. Thank You
    7600 gallons
    May 2008
    Jackson, NJ
    38
    Re: question on raising Ph
    Since I last posted on this subject things have been fine. I have been adding Borax a few cups each week to maintain the PH level. PH was always at 7.2 or 7.4 We have had very hot weather and using the pool alot lately, PH was back down at 6.8. Well I dumped a whole 4lb box of Borax in tonight ran the filter for a few hours.PH shoot up to 7.8 and the chroline level went to below .5 I know this is pool 101 but how do I keep the PH up with not knocking down the chorline level
    7600 gallons
    Guest
    Quote Originally Posted by jacksonjohn1961
    The problem is that your TA is probably too low! Please post a FULL set of test results and we can help you. You need to be testing for more than just total chlorine and ph (which suspect is all you are testing for or you would not really have this problem to begin with!)
    30,421
    That's not helping. pucks are VERY low in pH.
    Sun and organics reduce FC.......Adding borax is irrelevant.
    I'd suggest going up into pool school and reviewing the basics and, as waterbear said, you'll need a test kit that'll tell you more about your pool. You should be able to test for pH, FC, CC, Alk, CH, and CYA.
