Thread: New filter
    New filter
    I need to replace the filter elements of my Hayward 3620 de filter, it was destroyed when a tree took out the shed that I stored it in during the winter. I had my pool installed in 2007. My question is should I purchase a new filter, I was told that I should have a 48, my pool is 44 thousand gallons and the pump is a 1 horse power, for about $900 or purchase the filter elements for $600?
    Thanks Mario
    Re: New filter
    My wife just corrected me she said our pool is 24 thousand gallons
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New filter
    Welcome to tfp, Mjv12
    For your 24000 gallon pool we would recommend a minimum 66 sq. ft DE filter, though you can get by with more frequent backwashing/cleaning with the one you have.
    Your price to to replace the filter grids seem high to me...or do you need to replace more?
    Re: New filter
    The whole assembly was damaged. I wanted to get away from de so I thought this was the opportune time to go to a sand or cartridge filter I will the size you mentioned in mind
    Re: New filter
    I guess the next question is should I go to a sand or cartridge filter?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New filter
    Got it. Recommended minimums are sand 4.5 sq. ft. and cartridge 360 sq. ft.
