Thread: Polaris pb4-60 seal leaking
    My motor spun a bearing, so I ordered a replacement motor, new seals, and impeller (damaged removing it) . Assembled it all, water sprayed from pump housing rear seal. Disassembled and checked everything, and the stationary spring seal has a small chunk missing where it touches the impeller seal. It did not when I bolted it up.
    Also, the volute housing seal tube seems to be about 1mm larger than the motor shaft, and I cannot visualize how that seals.
    Any suggestions about what I am doing wrong? Or what caused the torn seal?
    My Pool: 18'x36' Grecian. Vinyl Liner, 500# sand filter, SWG.
    My hobbies: Brewing beer and flying rockets.
    22,553
    Re: Polaris pb4-60 seal leaking
    Can you post some pics of it?
    Sounds like some debris got left in there.
    Yes, I will get some pics tomorrow. That said, I disassembled, cleaned, inspected, and rebuilt it on my bench. Trash would have to come from the lines.
    I did hook it up backwards at first, perhaps it sucked in some trash?
    As a warning to others, this started as a project to replace the bearings. Unfortunately, I learned the hard way that if the bearing doesn't slip off easy stop and don't force it. I did and The bearing puller caused the threaded end of the shaft to mushroom just a little bit, ruining it. Now I have a new motor.
    Replacing the seals fixed the problem.
    Below is a picture of the first replacement that leaked. I cannot say for sure the divot wasn't there from the factory, but I fix pumps, engines, etc periodically and I would like to believe I would have noticed something like that in a brand new seal.
