Results 1 to 9 of 9
Thread: Pool Decking Recommendations
    Hi Everyone:
    I was happy to join this forum and hope I can ask for some advice and help. I recently bought my home and have been learning the ins and outs of pool care. I have had a new T-15 cell replaced for my Aquarite SWG and also had a suntouch connection and box placed for my solar water heater. My question is decking around the pool. I have included some pictures of the decking currently and I am wondering what is the best remedy for dealing with the issues in the attached pics. You will seem some staining and also hairline cracks and also some areas in need of repair on the decking. Is there a reasonable way to accomplish this or do I need to have the entire deck resurfaced to repair the holes and cracks and staining? Also, could someone give me an idea of what this might cost? I have included a picture of the full pool also as a point of reference. Thank you for any insight and help! Mahalo!
    HawaiiGuy
    20 by 38 kidney shaped pool
    SunTouch Pool and Spa Panel
    Pentair Variable Speed Pump
    Aquarite SWG
    T-15 Cell
    Pentair Triton II
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Pool Decking Recommendations
    Here is a picture of my pool. It's a vinyl textured surface over concrete. It is great for a salt pool, comes in many colors and will hide a multitude of sins. Relatively inexpensive. You can even imitate stone, or other surfaces (for additional cost). Here is a picture to show the texture before the color coat was applied.
    chiefwej
    May 2012
    Northern Connecticut
    103
    That is a really good looking patio! Wow!
    24,000 20x42 double roman end in ground pool being built. Start date june13, 2012.
    Finished July 4th, 2012, sports pool, vinyl,SWG, DE filter, fountains. Heat pump,
    First Pool Ever!
    4knights's Avatar
    NE Kansas
    419
    chiefwej
    What is the brand name of the coating? Did you apply it or someone else? What is the color you have? This info will help the OP and the rest of us.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Chiefwej: Thanks for your message and the pics. Your deck looks fantastic! Is it a topical application and will it fill cracks or chips in the cement also?
    Mahalo,
    Dan
    HawaiiGuy
    Aquarite SWG
    T-15 Cell
    Pentair Triton II
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    The cracks are filled and patched before the texture coat goes on (see photos). Textured coat is mixed and applied with a texture gun, the "knocked down" with a trowel. It's the same process (albeit different materials) as is used for textured dry wall. Then a color coat is applied when the texture is dry. The color coat can be refreshed or the color even changed in the future. I recoated the deck after five years of use and it looked just like new. The result looks much like KoolDek but it is non porous and is much more durable. Textured vinyl over concrete is a very common deck surface in this part of the country, and particularly well suited to SWG pools. There are many manufactures and suppliers, for my deck I used products from Preferred Deck Systems.
    http://prefdeck.com/
    chiefwej
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    The OPs deck looks like it may be an old KoolDek application that is peeling. If so you need to remove any loose or peeling material, patch any cracks then repair and fill in any missing textured areas, then it can simply be recoated with the vinyl color coat right over the old KoolDek. I watched one of my neighbors do that a couple years ago and it's holding up great.
    chiefwej
    Jun 2014
    SoCal, Ca
    80
    My builder & I haven't gone over decking options. I'm interested in the vinyl over concrete decking- how much per sq ft does this run?
    petrocomical's Avatar
    Apr 2013
    Baton Rouge Louisiana
    16
    X2 ..pp sq ft???
