Thread: Do I need a bigger pump?
    Apr 2013
    Southern California
    29
    I have a 15 x 30 / 3' x 7' and I'm running a hayward maxflow II 1 1/5 HP pump 240V.
    Its a SP2810X15: Pump Output (GPM) vs. Total Resistance To Flow (Feet of Head) ==
    20ft/83, 30ft/74, 40ft/64, 50ft/51, 60ft/34
    I have 1 1/2 inch pipe with two pool returns and 1 skimmer
    do I need to give any more info?
    I was looking at the 1 1/2 HP super pump I and II either of these any better? or am i fine where I'm at?
    17000 gl. In-ground vinyl pool
    Naturesoft/aquarite SWG t-15 cell
    Vinyl liner measured and installed by me
    Re: Do I need a bigger pump?
    Unless you have a fountain, waterfall, spa, or something similar you want the smallest pump possible. So, if anything, I would recommend getting something smaller. Of course, replacing a working pump is almost never worth it, unless your electric rates are very high.
    Apr 2013
    Southern California
    29
    Now that is music to my ears!
    May 2009
    Youngsville NC
    395
    Pool stores / builders typically oversize the pump and undersize the filtering system per the usual recommendations at this site. OTOH - as stated above - I would not be in a big hurry to swap out a perfectly fine working pump just to change sizes either, unless the payoff is really quick (1-2 years).
    If your current pump actually needs replaced - then by all means - change to a smaller, more efficient pump (two speeds and /or multi / variable speeds are both popular options, depending on your power rates).
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
