Thread: Drainable Trash Can
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Drainable Trash Can
    I have several mature tulip poplars that overhang my pool. The cost to remove them is prohibitive at this time (8K each, ). To make matters worse, I will need to replace the skimmer plumbing lines since the previous owner dropped chlorine tabs which crimped the line. In the mean time, I have to manually skim twice a day to fish out tree debris. In the past, I would dump the debris on the hill behind my pool, but this was futile because the piles would get large and my lawn forgets to clean it up and the wind tends to carry it back into the pool.
    I've taken a trash can and put in a lawn bag and punched a few holes in it to drain the water, but the bag tends to rip. So, does anyone have ideas? I am not interested in composting, so something that drains the water so I can bag it. I wonder if I just dump the leaves in the can without a bag and then dump it into a bag once a week. Thoughts, ideas??
    Karen
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Drainable Trash Can
    My suggestion was going to be one of those roller composting bins
    4knights's Avatar
    NE Kansas
    419
    My suggestion was to get a few pallets from any store(free) stand them up (box shape) where you currently dump the debris and simply put a mesh net over them. They will degrade on their own and produce some great compost for the garden.
    If you really want to, you could drill a bunch of holes in the bottom of your trash can and set it on a few bricks to let drain then dump in a bag.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Mar 2013
    Yucaipa CA
    87
    Use a smaller trash can, maybe like for a kitchen or bathroom, with holes in the bottom to drain the water. When you go out to skim the pool empty the dried stuff out of the small trash can into your regular rubbish can and then put the new skim in to dry again over night and start the cycle all over again .The smaller can will be easier to carry and dump than a large one full of debris.
    skeeter
    47 yr old(1977) 18,000gal Kidney shaped 38ft long plaster Pool with built-in Spa, Pentair Intelliflo VS3050 Pump, Pentair 48sf DE filter, Raypack RP2100 gas heater. HTH 5-way test kit
    Jul 2009
    Olney, MD
    218
    Maybe the quantity of your skimming is too much for this method, but anyway, I usually use a leaf rake for skimming which has a fairly large capacity and then hang it up when full. So the next time I go to skim, I empty the now dry material and then start to skim. It is a lot easier to empty when completely dry.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Skeeter, I like your idea and I have an unsued small garbage can that I can to put to use.
    J20832, I fill my large leaf rake several times each time I skim.. and I skim twice day.
    Thank you all very much!
    Karen
    Karen
