Results 1 to 9 of 9
Thread: Bleach or Dichlor?
    Mar 2013
    Wichita, KS
    11
    Bleach or Dichlor?
    Our pool is being installed in the next few days so I am reading and rereading pool school.
    I do have a question... Under the Seasonal Pool Section there is a are that addresses the First four days of opening your pool. Step 5 - the first four days
    The first few days will be spent using dichlor to add chlorine while also raising your CYA level to help protect the chlorine from the degrading effects of sunlight. If you want to be able to jump into the pool as soon as it's full, use the Pool Calculator to determine the amount of bleach needed to raise your chlorine level to 6 ppm. Add that amount of bleach while the pump is running. Wait an hour to let it circulate before you use the pool.
    The first four days, you will use dichlor to both chlorinate your pool and raise the level of CYA (chlorine stabilizer). The first evening, after you're finished swimming, turn the pump back on, test and make any adjustments to pH. Let the pump circulate any chemicals added to adjust pH (30 minutes or so) and then add one ounce of dichlor for every 500 gallons of water. To add the dichlor, add it first to a bucket of pool water and let it dissolve, and then dump that into your pool. Let the pump run overnight. This dichlor addition will raise the chlorine level to about 8 (assuming no chlorine was added prior . . . if it was, the chlorine level will be a little higher, which is fine), and the CYA level to 8.
    Repeat the above procedure each evening for four nights total. At the end of four nights, your CYA level should be around 30, right where it should be. After four evenings of adding dichlor, STOP USING THE DICHLOR.
    So I am not sure what to do when my pool gets filled. Do I add the dichlor for four days or do I just add household bleach or both?
    Also, can you swim during these forst 4 days? Can you swim ever during shocking?
    Thanks to all of you! I am so excited to get started!
    18x33ft oval AG, 15,000 gallons
    22" BlueWave Sand 1.5hp
    04/2013
    I use and endorse the TFtestKits TF-100 from http://tftestkits.net
    38,521
    Re: Bleach or Dichlor?
    If it is a new fill, you do not need to go through the shock process.
    Using dichlor is a short-cut, and being new, I would suggest you stick to the "pure" chemicals. Buy stabilizer and add it separately and stick with liquid chlorine.
    Have you ordered one of the recommended test kits yet?
    Smykowski's Avatar
    Sep 2011
    3,065
    Welcome!
    Take a look at the ABCs of pool chemistry in pool school, that will help. I'll try to clear up a little here as well.
    Stabilizer (or CYA - cyanuric acid) is needed to keep chlorine from burning off in the sun too quickly. Dichlor has chlorine and cya in it, bleach has only chlorine. The water out of your hose does not, so you need to add it. Dichlor is used at first because it adds both. At some point though, you need to stop using dichlor and switch to bleach, because too much cya is bad as well.
    Yes you can swim right away, and with a fresh fill and properly maintained water, you shouldn't have to shock it.
    Read all of pool school and it explains this in more detail.
    Mar 2013
    Wichita, KS
    11
    I ordered the TF100 test kit. It should be here by the time the Pool is up and running. So I have 2 mixed responses. One says use dichlor the other says bleach and stabilizer... YIKES!! I need a tiebreaker response.
    04/2013
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Both ways will work, one is just more stuff to juggle, let me add a little more to that, if you want to use dichlor (or even trichlor) there is no reason you can't you just don't want to overdose on it before you switch to bleach / liquid chlorine for long term use. The dichlor instructions are mostly a cheat for people with seasonal pools that will be drained at the end of the season that don't have good test kits that include the CYA test. Personally when my pool needs a CYA boost I switch to using dichlor for a few days then back to bleach, it just means keeping track of how much FC as well as how much CYA each pound of dichlor adds.
    38,521
    It is by far simpler to understand and verify the results of the chemicals you add by sticking with the separate chemicals.
    Now if you had some experience already, then the use of some of the combined chemicals is fine. But, you need to understand ALL the effects of each chemical you are using.
    Mar 2013
    Wichita, KS
    11
    OK! Ill get back on in a few days and post my first results. Thanks again!
    04/2013
    Smykowski's Avatar
    Sep 2011
    3,065
    Sorry, my run on sentence up there was just trying to make it clearer (major fail, btw) so that you coulde make your own decision. As for my opinion, I'm with blizzle. Use granular cya and liquid bleach. Much easier to deal with the chemicals separately when you're still learning.
    Jun 2012
    Howell, NJ
    977
    I agree that since you are new, you should use bleach and stabilizer separately. If you were to use dichlor, you would be raising CYA and CL, and also lowering pH. You have much more control by using single chemicals.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
