Results 1 to 8 of 8
Thread: Brand new to TFP
    Apr 2013
    Davenport, FL
    5
    Brand new to TFP
    Hi Everyone! (Apologies in advance for a long post)
    I found this forum while searching for a way to try and find a cheaper/better way to care for my pool. I've owned the house (and the pool that came with it) since 2009, and so far, the pool has survived on a steady diet of chlorine tablets, advice from the local Pool $tore, and 2-3 yearly treatments of green-to-clean. So far already for 2013, it's been treated 3 times, and we haven't even gotten to the summer.
    Before I found this site, I really didn't know anything about pool care. I really still don't. And, more than that, I'm a lazy pool owner. My idea of pool testing is to dip a test strip in the water every few days, and/or take a sample to the pool store every 2 weeks or so.
    My pool information is in my signature, and there's a picture of my pump equipment later on in this post. (I never use the heater ... too expensive). The pool doesn't get used terribly frequently, maybe 3 or 4 times a year, although, if I can get the water cleaned up, I'd like to use it more often.
    Right now, the pool is looking a little on the green side, and there is some visible algae near the stairs. (See picture).
    I'd like to start with the BBB system, and try to get the pool back to looking "swimmable". I know that I'll need to do quite a bit of reading, and invest more time than I have been. Realistically, how much time do you think will be needed on a daily/weekly basis? Right now, I've got some liquid chlorine, some muriatic acid, and some tri-chlor pucks (that I really don't want to use) ... what other chemicals should I add to my arsenal? I'm also thinking (probably a year or two out) about a Salt Water Chlorine generator. Useful investment, or a waste of money?
    I stopped by the pool store today, here are my test results. Where do I begin?
    Free Chlorine: 5
    Total Chlorine: 5
    Calcium Hardness: 450
    Cyanuric Acid: 60
    Total Alkalinity: 110
    pH: 7.6
    Phosphates: 300
    (I'm also not quite sure about the 7500 gallon figure, but the Pool Calculator seems to agree, based on the dimensions of the pool as measured below)
    Central Florida | 7500 gal | Inground | 1HP Motor | 75 SqFt Cartridge Filter
    Jun 2012
    Howell, NJ
    977
    Re: Brand new to TFP
    You need to first get a good test kit. Either the TF-100 or K-2006 from tftestkits.net. After you get the kit and do your own tests, you will need to follow the shock process detailed in Pool School (upper right). While you are waiting for the kit, read up on clearing algae threads and keep your FC up with liquid chlorine or bleach. You will want to keep your chlorine above 5 ppm all the time, if your CYA is truly 60. As to how long it takes to maintain the pool... While shocking you should be out testing and dosing chlorine every hour if possible. After the pool is clear, it takes maybe 5 minutes a day to test, add chlorine and adjust pH, if necessary.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, SyracuseWolvrine
    My calculations gives me about 5500 gallons for your pool.
    Quote Originally Posted by SyracuseWolvrine
    Once you get up and running on the methods here...5 minutes a day, and maybe 20 minutes more once a week. If you maintian per our recommendations, then you avoid problems and that keeps you in the pool and not troubleshooting the pool.
    Useful, but not necessary. Will not save you money, but won't cost much more either.
    First, get your own test kit. Pool store results are very unreliable and you want to be able to test daily. See this pool school article: http://www.troublefreepool.com/pool-...pool_chemicals
    With that said, ignore the phosphate test result since with a properly chlorinated pool can have very high phosphates without issue. Other than that, you CH is a little high as is your cya, but both are liveable. See this pool school article: http://www.troublefreepool.com/pool-...mmended_levels
    I would hesitate to do too much with those test values since they may not be correct (pool stores get the cya test wrong more than right) and get you own test kit.
    Smykowski's Avatar
    Sep 2011
    3,065
    Welcome to TFP!! I got some serious deja vu reading your first post, because I was in exactly your shoes 18 months ago.
    The only thing I'd add to the above is do not stray from the advice you get here. You can do it our way, or you can do it the pool store way, but you can't do both.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What they said, get a good test kit ( see my signature for the TF-100 link), while waiting for it to get in, read over the pool school link in the upper right corner, take a break and read it again, most people get a lot more out of it the second time around. Once you get your test kit in, run your own tests and post the results and we will try to get things going for you. Sure some pool store tests are better than others, but in our overall experience if you take a water sample split it into 3 parts take to 3 pool stores you will get 3 very different set of test results.
    Apr 2013
    Davenport, FL
    5
    Thanks for the welcomes. I will be looking at the test kits and purchasing one before the end of the weekend.
    Once I get the test kit ... should every test be done every time I test? Are there some tests that should be done more frequently? Is weekly good, or more often?
    (I'm sure I'll have more questions as time goes by)
    38,548
    You do not have to do all the tests all the time. Here is a general schedule when the pool is clean:
    pool-school/basic_pool_care_schedule
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The link Jason provided is a good starting point, but each pool is different, once you get the hang things it is likely you can drop down to testing the basic stuff (probably pH and Chlorine, maybe even just Chlorine if your lucky enough to have relatively stable pH) 2 or 3 times per week, then a more complete test every week or two. Again depending on the pool, hardness of fill water, and the overall trends you may find that some tests like CH can be dropped to every 2 or 3 months, but this is only after you have established a long term trend.
    Ike
    p.s. Personally I would move checking filter pressure to the daily or every other day routine instead of weekly
