Results 1 to 15 of 15
Thread: Backswimmers and Bioguard Backup
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I have a few of these bugs and was looking at buying some Bioguard Backup to kill them in the event they get bad like they did last year. But, its expensive and I would need alot of it. I read in a previous thread that any algaecide with 50 in the name would do the same. So, that being the case, is this a good substitution?
    http://www.intheswim.com/Pool-Chemicals ... RRWidgetID
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Backswimmers and Bioguard Backup
    Backswimmers aren't algae...so I doubt that would help. Are you running Baqua in your pool? They can be stubborn little guys, but sufficient chlorine will kill them.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    No. I use the BBB method and my chlorine was as high as 26ppm last year for several days in a row last year and they lived through it. I just looked at my pool and its crystal clear except for some sand on the bottom from winter. This is more of a preventative measure. There are other threads on TFP about people using Backup as a method of killing these things.
    30,403
    I usually have some backswimmers in the Spring. I kept my pool cleaner this winter and don't think I have any now.
    Nevertheless, I have always ignored them and when I open the pool and clean it up with chlorine, they ALWAYS have gone away. You can use anything you like in your pool, of course. Many others on the forum have reported similar success using just chlorine so that's always gonna' be my only choice.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Maybe I am not chlorinating enough for a long enough time. What should I shoot for as far as ppm and for how long?
    30,403
    What is your CYA?
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Its at 35 right now but I am going to run it back up to 50 this weekend.
    30,403
    Assuming your water is clear and you are not doing the shock process, I would bring FC up to around 8-10ppm and HOLD IT THERE for several days.....thats also with your CYA going to 50ppm.
    That should send them packing and will cost very little.
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I have had it at 10 for the last week. Maybe that is why I don't have any right now?
    May 2009
    Mn
    198
    Are you near swamp land at all? I never had cc last year and still had water boatmen and giant water bugs. We treated for mustard algae even though I knew that wasn't the problem. We did phosphate removal(the flocculant was a mess) and we use algaecide.
    We've resorted to the fact that it is just where we live. Their probably in the lake too but you just can't see them!
    Let me know if you find a solution. I hate bugs having a party in my pool when they aren't invited!!!
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Consider Borates - If I recall from prior threads on this forum users report success with Borates.
    Apr 2012
    SW Ohio
    456
    i love my borates....i did read on here somewhere that bugs don't like water with borates in it and it also works as a algae deterant.....
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Feb 2008
    Denton, TX
    5,061
    As long as the insects ingest water with borates, it will kill them. Not sure if backswimmers do that or not.
    May 2009
    Mn
    198
    Glock,
    Sorry your thread got off topic, but I think the idea is that you can put in algaecide, but it isn't likely to keep the bugs away.
    We used borates (at 50) and still had them. They were mostly in the spring and fall. I just think our pool is too close to the swamp so we are the first place they dump. My sister has had algae in her pool and she has NEVER had the bugs. She lives 40 miles away, but suburban.
    Good luck! I think a small fish tank net to scoop and squish is your best option.
    It does work!
    I shocked the shat out of our pool over and over and took the chlorine levels so high I thought my liner would melt. And it those water bugs wouldn't die. We had all kinds of water bugs..
    I ordered some BioGuard Back up Algaecide off Amazon and put in the whole bottle into my 33' round pool. KILLED them ALL!!
    Thank You WHOEVER posted this years ago.
    IT WORKED FOR US!!!!
    26,000 gal Round Artesian. 2 speed Water-Way pump. Sand filter. Robo-Kleen. Pool-Skim.
