Thread: Returns & Skimmer
    eap2313's Avatar
    Apr 2013
    Lewisville, TX
    37
    Returns & Skimmer
    While vacuuming my pool I notice a return (just one) was spurting air bubbles. I cut pump off then back on and it seems fine. Was this just a sign of air getting in? I think when I started the vac it came out of the pool a bit.
    I have 2 skimmers and one doesn't seem to pull water like the other. Is this a plumbing issue?
    Eric
    16K gal Plaster Pool (built approx. 1999)| 2HP Purex Triton WhisperFlo Pump | Polaris PB4 Booster Pump | Purex Triton Sea Horse Cartridge Filter FSH 500 (DE grids inside) | Hayward Vari-Flo Valve | Compool 3-Way Valves | Chlorine/Bromine Feeder Model 320 (Rainbow Lifegard) | Laars Lite Heater | Whisper Jet II (Tropic Air) | 6'9" x 6'9" Spa
    Dallas-Ft. Worth Metroplex
    38,524
    Re: Returns & Skimmer
    Likely the bubbles were just from a little air in the system. Have you opened the air valve on the top of the filter to purge any air?
    The imbalance of the skimmer suction may just due to the different pipe lengths. But, depending on how your pool is plumbed, you can probably do something to better balance them if you wanted.
    eap2313's Avatar
    Apr 2013
    Lewisville, TX
    37
    That's what I thought. What could I possible do to level them? It doesn't seem like a major issue since the one that isn't pulling water as hard is actually further from the pump than my other skimmer.
    38,524
    Are the plumbed separately to the pump? If so, you could close the near skimmer a little to force more suction from the far one ... although this will actually result in a total flow that is slightly less.
    eap2313's Avatar
    Apr 2013
    Lewisville, TX
    37
    I only have 1 skimmer piping connected to my valves so I would assume they are not separate.
    38,524
    Hard to know how they are connected and whether they are adjustable or not. It could be that the far skimmer is plumbed to one of the holes in the near skimmer and then the 2nd hole goes to the pump ... but this seems like an odd setup.
