Thread: Recommend pool brush.
    jkurl's Avatar
    Fairfield, ca
    141
    We are in need of a new pool brush. The one we have is just wore out and the bristles are coming off in the pool. This was the starter brush the came w/ the pool starter kit. We have a plaster pool and have a SS brush but I only want to use it for algae. I looked at the whale tail brushes. They got great reviews but I wanted to check with you all to see what you might recommend. The whale tail brushes are about $30. I am not opposed to spending that much just want to see if there are brushes that are cheaper and just as good.
    Jerry
    Pool Size: 20 x 40 Free Form Inground Plaster Pool w/ a shallow cove.
    Gallons : ~23K Jandy CL580 Cartridge Filter, Jandy e-pump 1.5HP
    Polaris 280 w/ Booster Pump, AqualinkRS PDA4 Remote, Aqua-Pure SWG
    Jandy LED Pool Lights (2), Heliocol 500 Sq. Ft solar rack system
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Recommend pool brush.
    They're awesome. Old Threads
    jkurl's Avatar
    Fairfield, ca
    141
    Richard,
    Thanks for the wall whale threads. I just did a search for pool brushes. I think the wall whale might be the one.
    Jerry
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    When you look around at all of these pool service guys, none of them use brushes like this and they are cleaning hundreds of pools a week. Wouldn't you think if an item was so great, a "professional" would be using it? Wouldn't they want to save time so they can clean more pools and make more money?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    jkurl's Avatar
    Fairfield, ca
    141
    Quote Originally Posted by ps0303
    I couldn't tell you what they use I clean my own pool and when the PB did his initial care the 1st 30 days he just used our brush.
