Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Help
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Help
    How do i get TA lower without raising PH ???
    Trying to bring up levels after absorbic acid treatment
    PH=7.2
    ALK=130
    FC=1.0
    CC=4.0
    TC=5.0
    CYA=100
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    38,290
    Re: Help
    Lowering TA does not raise pH.
    See this article from Pool School:
    pool-school/lowering%20total%20alkalinity
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Help
    Yea i frazed that wrong..
    How do i get TA of 130 Down to 80
    PH is 7.2
    MORE ACID ???
    Sean Hannon
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Help
    Lower PH to 7 using muratic acid (acid lowers PH and TA), then aerate your water to raise PH to around 7.6 without raising TA. Repeat, until you reach your target TA
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Help
    You need to aerate to get pH up. Then add acid to lower pH to 7.2, then do this process over and over. There's an article in pool school as well.
    How did you get your test results? If they're accurate, you've got other things to worry about before getting TA in line.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Help
    I used the TF 100
    Sean Hannon
    38,290
    Re: Help
    Not sure why I overlooked the obvious
    You need to be focusing on your very high CYA level and the fact that you have high CC before worrying about TA.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Help
    CYA of 100 is too high and should be lowered via water replacment first. Also CC is way too high and should be addressed by completing the shock process described in pool school.
    Edit...Jbizzle beat me to it!
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Help
    So the CYA requires a 50 % water change?
    I put a whole bucket of the solid conditioner in guess i screwed up big time !!!
    So thats making my TA hard to control ???
    Sean Hannon
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Help
    Thats the only way to lower cya. You should put your pool specs in your sig.
    Jeff
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Help
    Done .. Thanks !! Guess i gotta rent that honda pump i used last time !!!
    And buy some salt..
    I did a absorbic acid treatment to get rid of some brownish stains , pool looks good but last month stains came back after shocking. Right now i have the metal sequestered with jacks magic purple stuff, would a complete drain and fill get all the metal out for good ?
    Sean Hannon
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Help
    What size was the bucket of cya?
    Quote Originally Posted by Seanhan
    Yes, if of course it is metal free water Also, as you add make-up water, if that has metals you levels will slowly creep up (though it will take a long time). Beware that completly draining a pool is risky if you have a high ground water since that can "pop" your pool up.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Help
    The CYA was the 3-5 lbs I don't remember.. It was from leslies
    Sean Hannon
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Help
    It was 4 lbs
    Sean Hannon
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Help
    What was your CYA reading prior to adding the container of CYA? CYA does not make TA hard to control, however High TA fill water can present a challenge.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Help
    Must have had some cya in there already. 4lbs wouldnt have been enough to raise it to 100 in 30,000 gallons of water unless there was some in there already. Should've tested before adding.
    Jeff
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Help
    Quote Originally Posted by pwrstrk
    Thats what I'm thinking too. That 4 lbs should have only raised the pool by 16 ppm cya.
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Help
    Yea I did not have a good cya test . But I do now .
    Sean Hannon
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Help
    So you got the 100ppm of cya with the old or new test kit ?
    Jeff
  20. Back To Top    #20
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Help
    No the old testkit i got zero i thought ,then i ran out of regent, than i added 4pounds all at once
    Now with a good test kit its around 100
    Sean Hannon
