Thread: Opening questions
    Opening questions
    what chemicals do you recommend for opening - in eastern pa, open 5/15, close 9/15
    leslies seems to sell a bunch of junk in their opening kit, this year I am switching pool guys/debating opening myself.
    should I just go with 5 gallons liquid chlorine and some algeacide (need a recommendation).
    I have a mesh cover that is pretty beat so I get a decent amount of debris over the winter. but up till now opening by 5/15 the water has been ok within a couple days.
    24K gal, plaster, concrete decking, cantelivered coping, 20 years old, raised attached stone spa - 1 1/2 HP purex triton pump, 3 yr old 48 sq ft Pentair DE filter with multiport, Polaris 380 w/pump, 2 yr old Pentair mastertemp 400k heater - live in southeastern PA outside phila.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,101
    Re: Opening questions
    Test Results
    That's the start we'd suggest for to start any season. It's hard for us to say dump xyz into the pool, without knowing just what your chemistry is. You'll save a TON of headache's and money by switching pool guys, and taking care of 100% of the work yourself.
    38,475
    The smart/cheap method of opening is get the equipment running and all the nasties scooped out and then do and post a full set of test results using one of the recommended test kits. Based on that information you will know what to buy to adjust the chemistry.
    If you closed correctly, and open when the water is still cool enough, the pool should not have turned green.
    If it did, then you will want to go through the shock process as described in Pool School after getting a set of test data.
    Sticking with liquid chlorine and separate chemicals (CYA, baking soda, acid) as needed is the simplest method.
