Thread: Attached spa, jets barely turning on
    Hi all! This is my first season with a pool. We moved to Texas this winter and bought a house with a chlorine pool, about 10,000 gallons, and an attached spa. The house was built in '89, I think the pool and most of the motor equipment are original.
    We've been using the hot tub often since we moved in, about 3 months ago.
    My husband shocked the pool a few days ago and left the pool jets on for several hours after.
    I'm pretty sure we've used the hot tub since then, but I'm not positive.
    Anyway, now the hot tub jets just barely come on. I can see some kind of movement in the water, but thee definitely not ON, on, ya know?
    Any suggestions on where to start looking to trouble shoot would be much appreciated.
    Thanks!
    Katy
    38,430
    Re: Attached spa, jets barely turning on
    Why did you shock the pool? Was there algae or cloudy water?
    When was the last time the filter was cleaned? What is the pressure now and what is the pressure when the filter is clean?
    We need more info about your setup and chemistry:
    Help us help you. Please add your pool details and location as described HERE
    Are the pool jets still going? On my pool you have to turn a set of valves to divert the water and "turn on" the spa. I am just thinking maybe this is as simple as turning some valves.
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, darlinkaty
    Post those details jbliz mentioned and we can help!
