It really depends on your plumbing. Pumbing with more restriction (high pressure loss) then the maxflo will have lower flow than the super vs, if you have very unrestricted plumbing (low pressure loss) the the maxflo will have higher flow than the super vs.dprante said:So me trying to learn all of this, it seems the ratios are not easy comparable between the two, but the maxflo moves more water, right?
Either one does not appear to me to meet you higher flow requirements during simultaneous skimming and vacuuming. Is doing them at the same time that critical? It could get expensive, and might not even be feasible if you do not have separate runs or big enough suction side plumbing.
