Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Pump Replacement - Is anything TOO efficient?
    I need to replace my Hayward Super II pump. Motor went out, and everything from my setup is just old. In researching variable speed pumps, i am finding some really great options, and they come with great prices.
    Here is what i have, 30,000 gallon pool, with a sand filter. 2 inch lines all around I can go anywhere from a Hayward Super Pump Variable speed to a Pentair Intelliflo XF - i understand the higher end will cycle my water faster, but from what i know, it doesnt hurt to cycle the water slower. I was leaning twards a variable speed on the lower price range. Is the benefit of spening more money worth the benefit of the higher end?
    And another semi-technical question. I have a vaccuum, and was wondering how this will work with the variable speed pumps. Is it just the matter of having the pump run on high speed for the first hour everyday to get the vaccuum to work, and then let the pump calm down to cycle the water to turn over the water? Is it okay to leave the suction at the non propelled vaccuum at the bottom of the pool?
    I feel like i am in the shallow end but still over my head.
    30,000 Stressful Gallons - Inground Plaster - Cleaned with a Sand filter - 1980's construction
    Two Kids - Love the pool, and love to watch me work on it.
    - Dave
    30,403
    Re: Pump Replacement - Is anything TOO efficient?
    Welcome to the forum. I have been at or near the shallow end for about 10 years now. My mother always told me not to venture too far into the deep end.
    Have you considered a 2-speed instead of a VS? Quite a bit more economical and you typically run them on low for most of the time turning them up only to vacuum or run a water feature.
    The size of your filter is quite important in determining the correct HP pump.
    Thanks for replying! I have a hayward pro series high rate sand filter - model s244s - effective filtration area 3.14 sq feet, 20 GPM filteration rate, and 62 GPM Backwass design flowrate.... does this help me? maximum pressure is 50.
    - Dave
    Apr 2011
    Warner Robins, GA
    245
    To echo part of Dave's post above- I find with my VSP I really only use 2 speeds.....I only vary things when I'm "experimenting"
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    So, going with a 2 speed pump - the appropriate way to operate with a vaccuum would be to have to on high speed while vaccuuming, then lower it to cycle the water. Is it okay to cycle the water through the vaccuum?
    - Dave
    38,248
    It would be best to only be pulling through the vacuum while it is actually ... well, vacuuming and then pulling from the skimmer at other times.
    The problem is, now you are starting to talk about some level of automation to be able to automatically select speeds and change where the suction is coming from.
    You could just add a timer to have the pump run on high for a little while to vacuum and then on low for more circulation but still pulling through the vacuum. Currently do you have all flow going through the suction cleaner? You may only need some of the flow to have it function and the rest from the skimmer ... but then again, we do not know your plumbing setup.
    22,542
    The payback on a variable speed vs. a 2-speed is also dependent on your electric rate. If you live in an are with high electric rates you still might want to consider a VS.
    You can buy a timer that will operate a valve actuator an your pump. If you have a dedicated suction line that you leave the cleaner hooked to, that might be a good idea for you.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Not to stir the pot, but the new Superpump VS (variable speed) is intriguing. It is only ~$100 more than a 2-speed super or super II.
    Leebo has looked at it some and turns out it was a drop in for his old super pump plumbing: http://www.troublefreepool.com/haywa...mp-t57039.html
    i love the moderators. That is the first time i have ever said that. LOL. Back when the house was built in the 70's, (Phoneix, AZ) and they had to use charges to break up the rock that the pool sits in, there were two pumps, one for the skimmer and one for the "sweep". Since then, and before i move in (two years ago), the two lines were connected with a valve (jandy valve?) that regulates flow to the current, now-busted, 3/4 HP SuperPump II. I have never been able to run both the vaccuum off of the sweep suction line AND the skimmer -Although i would love to be able to. In theory, i could put a variable speed pump, or two speed pump on high, run both for the first hour or so, then the time switches the pump to a lower setting (built in timer on superpump VS) and then the water circulates, from the vaccuum and from the skimmer. Right?
    - Dave
    38,248
    Quote Originally Posted by dprante
    Right?
    Right.
    OK, so we need a smiley of a fat guy beating a dead horse, becuase i would use that right now. Variable Speed Pumps - they dont really have a horsepower rating, becuase it all depends on what speed they are running. BUT i need to ensure whatever variable speed pump or two speed pump i get can run both suction pipes at the same time and actually work the vaccuum. BUT, how do i know what speed that should be?
    - Dave
    38,248
    I think the VS Super Pump is ~2HP at max speed ... or something like that. The Intelliflo is 4HP and the EcoPump is 3HP ... these are all from memory and may be way off
    In any case, you would just experiment to find what RPM gave you enough suction to run the vac and the skimmer to your satisfaction. The lower the speed, the less electricity used ... so that is your trade off. What is good enough while not costing too much to run?
    IntelliFlo at max speed is just slightly less than a 3 HP WhisperFlo. The EcoStar at max speed is just a tiny bit smaller than the IntelliFlo. The Super Pump VS at maximum speed is just slightly smaller than a 3/4 HP Super II, ie way smaller than the other two. In some situations that is a good thing, in others not so much.
    38,248
    Wow ... I was way off.
    I did not realize the Super Pump VS was that small. Seems like that may not be powerful enough to do what drante is looking to do.
    Dang. Back to the DrawingBoard i guess? Should I just go for the big Inteliflow? The lower the speed the more saving, right? So nothing is too efficient... its only a few more hundred dollars. ugh.
    THank you everyone for you help though, i would have made a grave mistake without coming here first.
    - Dave
    Can you let me know where you got this information? The Hayward spec sheet on the site is saying that its max hp is 1.5. Should i not trust that?
    - Dave
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I think JL was looking at the performance curves:
    You really can't trust hp ratings to tell much about a pump, you really need to look at the performance curves.
    38,248
    Interesting. Looks like that Super Pump VS is pretty similar to my Superflo 1HP 2-speed.
    Quote Originally Posted by linen
    Oh Wow... i never even thought to compare it like that but that is interesting isnt it?
    Thank you so much for point those figures out JL.
    - Dave
  20. Back To Top    #20
    Ugh, okay, so i was comparing the Super VS against the Max FLo -
    Super VS - http://www.hayward-pool.com/pdf/lite...LITSUPVS13.pdf
    MaxFlo- VS - http://www.hayward-pool.com/pdf/lite...TMAXFLVS13.pdf
    So me trying to learn all of this, it seems the ratios are not easy comparable between the two, but the maxflo moves more water, right?
    - Dave
