liner cleaning
waterhog said:
could someone tell me the best cleanser to use to remove the oil and grime around the top of the liner where there is no water?? :?
If you are very careful not to get any in the water - there is a product called Krud Kutter. I buy it at Lowe's in the pressure washer section. ALWAYS rinse with another sponge from a clean pail of water. Works great and I haven't encountered any problems with its use. Hope this helps.
