Thread: Acid demand test
    Jul 2008
    Dallas, Tx
    128
    Acid demand test
    Hoping someone can help me to get a better understanding of the Taylor Acid demand test and the reagents needed to run it. I have a new pool going in that I plan to do a bicarb startup on, and would like to be able to run the acid demand test. Once upon a time, many years ago, I had a test kit that ran the acid demand test, so I've done it before, but same as the kit is long gone, so is much of my recollection.
    The test kit I use now is relatively similar to the TF100, but was put together with parts of different kits I have acquired over the years. The pH test I use is the HTH comparator, which I believe is the same as the K1000.
    What I *think* I know:
    -The Taylor reagent for the Acid demand is R0005.
    -The comparator tube I use will not work.
    -I think the K2006 pH test uses R0004. I have a bottle of R0004 picked up accidentally to replace my R0014.
    What I need to know:
    -If I run the pH test in one of my 25mL tubes what volume of water do I use?
    -I realize I won't have a color comparator (or maybe I do, does my K1000 comparator have the same colors?), but is that important if the point of the test is to determine the acid demand?
    -Does the K2006 pH test run the same way: x volume of water, add 5 drops of R0004? Do I need any cl neutralizer, etc?
    -How do I run the acid demand portion of the test? It's been many years, but what I remember, you save the pH test and then add the reagent (R0005, right?) drop by drop to determine the amount of acid needed. What is my endpoint- clear, or another color change? What is my multiplier? Or, if I have absolutely no recollection of how to do this test, how do you do it?
    I realize that the Pool Calculator can give me a volume of acid to add, but also realize that is dependent on my interpreting the initial pH reading correctly. A few weeks ago I helped a local TFP new pool owner get his new pool up and going and we each interpreted the pH reading to be 8.4, independently, using our own test kits. Turned out, based on the amount of acid needed to get it into range, it was closer to 8.7. Lesson learned, above 8.2 and I'm guessing what the pH actually is.
    20k white plaster with blue quartz, IntelliFlo VS, Quad DE 100
    1000 gal spa with natural stone waterfall
    Beach entry with 2 bubblers. Pool built Spring 2013
    Jul 2008
    Dallas, Tx
    128
    Re: Acid demand test
    Update: I found the video on Taylor's website that shows how to perform this test with my current setup.
    For anyone else looking to do this, if you have the K1000 cl/pH comparator (this is the one in the TF100, right?) you need reagent R0015 for the acid demand and reagent R0016 for the base demand.
    This video explains how to perform them:
    http://www.taylortechnologies.com/produ ... deshow.asp
    22,553
    Thanks for posting that. I've never had need to do an acid demand, but can see the value of it in a few situations.
    Jun 2007
    New Jersey
    653
    I use it and like it for two reasons:
    1. You just do the calculation once to figure out how much acid for each drop of acid demand reagent needed for your size pool. No need for Pool Calculator, Tables, or fingers after that. (For me, one drop acid demand = 1/3 jug of MA)
    2. You can do your color comparison in the orange/yellow/barely red zone of the comparator rather than the red/redder/reddest part which I personally find challenging.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
