Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Speck pumps compared to Hayward
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    I have an above ground 24' with a speck a91 2hp 2 speed pump aswell as an astral pools sand filter. I haven't read a lot on speck pumps, how are they compared to hayward? Specifically the hayward powerflo matrix 1.5hp. Just wondering if the 1.5hp will move more water than the 2hp, as I've read in some cases is true.
    30' by 54 Above Ground Pool 22000 Gallons
    1.5HP 2-Speed Hayward Powerflo Matrix Pump
    24' 300lb Hayward Sand Filter
    TF100 Test Kit
    Youngest Pool Enthusiast(Hopefully)
    22,550
    Re: Speck pumps compared to Hayward
    According to the curves for both pumps, the SP1591 Matrix will move about twice as much water for the same head as the Speck A91-II will.
    Are you sure you have an A91. It's only listed up to 1 sfhp.
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Thank you for your reply bama. I checked the motor card and the model is a91-ll. How is this one compared to the hayward 1.5hp powerflo? I heard many manufacturers upsize the hp just to look more efficient. I didn't know of the speck would be equal or inferior to the hayward of lower hp.
    TF100 Test Kit
    22,550
    The Matrix SP1593 is the 1½ hp model and compared to the A91-II the flow is about the same for the same head pressures. The Hayward may beat the Speck a little, but it's only a couple gpm if that.
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Which would you go with personally? If you don't mind me asking. Also, have you heard of astral filter tanks? They any good? Also one more question: the powerflo matrix 2 speed is it 1.5hp on full speed and half that on the low speed? Or 1hp and .5 respectively.
    TF100 Test Kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Here is the curve for you current pump: http://www.speck-pumps.com/other/htm...l_A91_perf.pdf
    Here is the table (no published curve) for the hayward: http://www.hayward-pool.com/prd/Abov...1_14017__A.htm
    Looking at 40 ft of head, the speck a91-II is moving about 67 gpm and the hayward matrix 1.5 hp is moving about 62 gallons per minute..so very similar.
    Since your current pump is a 2-speed (I think?) then you are already aware of the advantage of a 2-speed. I would recommend the hayward 1 hp 2-speed matrix (SP15922S), since the 1.5 hp is likely more then you need.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Metallica
    I do not know the spec brand, but I liked that they had good data on their website. Were you happy with your pump? How many years did you get out of it? Why do you want to replace it?
    I am not familiar with astral filters, do you have a model number?
    2 speed pumps use ~1/4 the power (in watts) on low but pump 1/2 flow compared to full speed. In the end you can cut your power usage by 1/2.
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    It works fine now, I was just considering potentially upgrading to a hayward if it moved more water more efficiently. Bama, why does the speck say 2hp on it?
    TF100 Test Kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yeah, I am confused now. According to speck's site: http://www.speck-pumps.com/other/htm...l_A91_tech.pdf that is a 1 hp pump, and yours is labeled as 2 hp. Either way, running on low with your current pump should still be pretty efficient. When it goes, then maybe consider switching to something smaller, but still 2-speed.
    38,295
    Any chance the motor was replaced and you have a 2 HP motor running on a 1 HP impeller?
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Not sure It was bundled in when we bought the pool a year ago. I took a pic of the motor card ill attach it to this post.
    TF100 Test Kit
    38,295
    Hmmm ... that is curious. Well as long as it is working, I would not worry about it.
    Help us help you in the future. Please add your pool details and location as described HERE
    22,550
    There's a couple of things to look at on that pump.
    Notice that on the motor mfg's data plate there's no hp or sf. Pump vendors request them like that so they can play with the numbers to their liking. So it can be a 2 hp with a .5 sf. Now if you look at the real data plate you'll notice that it draws 11 amps on high which is consistent with a 1 hp 1 sf motor.
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    Bama, let me ask you to clarify something. I do not have a lot of experience with pumps of lower hp. Immediately after backwashing the filter, I can barely keep my hand infront of the return its so powerful. Are 1hp pumps just like that? Also my entire pool is extremely wavy right after backwashing, is that the same with 1hp pumps? Just wondering if I actually do have a 1hp.
    TF100 Test Kit
    38,295
    I do not understand. The more powerful the pump and the lower the head loss, the more suction and flow you will get. 1HP is on the lower end or pool pumps as they go up to 3 or 4HP.
    Likely the problem is that you are not cleaning the filter often enough so suddenly you think it is powerful. You should be cleaning it when the pressure rises 20-25% of the clean pressure ... otherwise the flow is greatly reduced.
    22,550
    As your filter gets dirty the head loss across them increases and therefore the flow reduces a lot. If you look at the curve for the speck pump you'll see that it doesn't take much rise in head to drop the flow a lot.
    Metallica's Avatar
    Apr 2013
    Birmingham, Alabama
    104
    I apprecite it. What I was asking though is, on 1hp pumps on above ground pools, upon immediate backwashing, will the return power be substantial as in you can barely keep your hand infront of it? On mine, upon backwashing, which I do once a week or when the return is noticeably deminished, I can barely keep my hand infront of it and my entire pool is wavy. I'm basically asking is are 1hp pumps that powerful aswell.
    TF100 Test Kit
    38,295
    They could be. Depends on your head loss.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    mas985's Avatar
    Pleasanton, CA
    11,737
    That is an SPL rated motor which means it is the equivalent of a 1 HP full rated motor (i.e. double up rated).
    Mark
  20. Back To Top    #20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Mine is like that.
    We recommend backwashing when the pressure goes up 25% from the clean filter pressure.
