Results 1 to 8 of 8
Thread: Stone Sealers
    Stone Sealers
    I'm having issues with my flagstone coping around my pool (SWG). The pool was built in 2007.
    I'm to the point where I'm going to have to try and seal the stone coping as well as the rock waterfall.
    Has anyone had any experience with the Dupont StoneTech Salt Water Sealer http://www2.dupont.com/Stone_Tech_Pr...nt_sealer.html
    11K SWG Freeform IG pool w/ spa; Bluehaven 550 (hayward mfg) Cartridge Filter; Century Centurion 2HP Pump on pool; Hayward 400H heater; Polaris PB4-60 Pump on cleaner; Hayward Super II Pump on waterfall, Hayward TurboCell GLX-Cell-5; AquaLogic PS8, Taylor 2006k
    Pool Chlorinator @ 80%; Filter from 11AM-6PM, Cleaner from 11AM-2PM
    Re: Stone Sealers
    Also I found this old threat dry-treat-natural-stone-flagstone-sealant-t3122.html?hilit=texas%20stone%20sealer, where they had images of their use oof "Dry Treat" product,
    This company also has the same exact same pictures but claim they use Dupont StoneTech http://www.texasstonesealers.com/
    Re: Stone Sealers
    I will be sealing my flagstone coping this weekend with the Dupont Stone-Tech product. I wanted to do it before I got the salt in the pool, but the coping guys had to make a few repairs this past weekend. The Dupont product was recommended to me by the PB, so if all goes terribly wrong, I'll be giving him a call.
    At first I thought it was terribly expensive - but then I found it cheaper on Amazon and it showed up at my door 2 days later. I will post a review of the product and installation next week.
    Best,
    Sciz
    Completed March 1, 2013. 12,500 gallon IG Lagoon Style w/swimout, walk-in steps, 15' x 30' x 3' - 5', Gunite, Wet Edge Technologies, Pebble Sheen - Northshore Tahoe, 2" Tennessee Fieldstone Coping, Belgard Country Blend Pavers, 1.5 HP Superflo, 19" Tagelus Filter, IC-20 SWCG.
    Re: Stone Sealers
    Update to my original reply:
    I just re-read the application instructions on the Dupont website. The sealer has to cure without chance of getting wet for 72 hours after application. Looks like I may be doing this another time since there is a chance of rain on Monday. Also, I intended to sweep and vaccum the pool this weekend, which always causes a bit of splash-out.
    I should also point out there is a difference between the regular stone-tech sealer and the salt water resistant sealer. make sure you get the correct one for your application.
    Best,
    Sciz
    Mar 2011
    Houston, Texas
    413
    Re: Stone Sealers
    I used Miracle 511 Impregnator on my travertine coping and I haven't had any issues in over two years.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Re: Stone Sealers
    I am planning to get the Stonetech Salt Water sealer. Sciz did you order on Amazon from StoneTooling?
    Re: Stone Sealers
    Sorry for the delay - I wanted to confirm. Yes that was the seller on Amazon. I paid $119 for 1 gallon (looks like now it is $0.10 cheaper (dang - shoulda waited). I recall looking for the same product locally (in Georgia) through a distributor - they wanted $225 a gallon so I was happy to pay what I did - hopefully it works.
    I am anxious to get this product on now that the salt is actually in the water and generating chlorine.
    Best of luck,
    Sciz
    Jul 2008
    Dallas, Tx
    128
    Re: Stone Sealers
    I will be sealing my flagstone coping with Dry Treat's 40sk, primarily due to the consolidation properties of the product. Although marketed as a salt water sealer (I do not have a swg) I'm using it because I've already seen some flaking on my coping that is only a few weeks old. The 40sk should bind and solidify the stone. I do not believe the DuPont sealers have the same consolidation properties.
    40sk is also a one time application which is very attractive to me. Because it does not sit on the surface of the stone it will not wear off. For salt water conditions they do recommend dip sealing the stone, which obviously won't be an option for you. I have been in contact several times with the regional rep for my area, he has been very willing to answer my many questions.
    20k white plaster with blue quartz, IntelliFlo VS, Quad DE 100
    1000 gal spa with natural stone waterfall
    Beach entry with 2 bubblers. Pool built Spring 2013
