Results 1 to 11 of 11
Thread: opening FC =0
    Herndon, Va
    65
    opening FC =0
    last year I closed with good values (cya=40,ta=7.2,ect) this yeat I'm getting ready to open and have a couple of questions
    The water temp is 57, pH=7.2, and FC=0 and just for understanding the CYA =40 From what I read here it says to bring the pool up to shock levels, but it says to bring it up to 3ppm. This is'nt what the table says shock level is, it says 16ppm. I can understand that after the winter I might not need to go to 16ppm but maybe I do, what is the correct level?
    I'm trying to gather up all the chemicals that I will need to open tomorrow.
    thanks for the help
    ____________________________________________________________ _____
    IG 25,000 gallon concrete painted pool,
    KDI American Products Model# 583090 Titan SS Vertical Grid 48sq ft DE filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: opening FC =0
    I'm assuming that is your PH# of 7.2 and not your TA. Shock the pool per your current CYA level of 40. 16 sounds about right. What is your TA? Might need to grab some baking soda is my guess..........then raise your PH back up.
    30,421
    Re: opening FC =0
    What does your water look like? Is your CYA still 40ppm?
    38,295
    Re: opening FC =0
    Where do you see the shock valve of 3ppm? That is not correct.
    What does the water look like? The safest method is to go through the shock process until you pass the 3 tests to stop. If you have little (none) growing in the water, then you will pass very quickly and be off to a good start.
    You have not posted a full set of test results, so further advice on what chemicals you will need is difficult. What test kit are you using?
    Herndon, Va
    65
    Re: opening FC =0
    Right I do need to get a full set of tests. I have a large kit dont remember that exact modeL But it is one of the reccomended kits here
    The thread on opening a pool at the top of this section In the detailed section it says 3ppm
    I will go through the process like you suggest right after I do a full set of tests But I'm guessing I will need at least 5 gallons of 8.25% bleach just to start...from the pool calc
    thanks for the help
    38,295
    Re: opening FC =0
    I have never read that sticky I am pretty sure that recommendation is based on no CYA in the water ... which is not true in your case ... at least we don't think it is.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Herndon, Va
    65
    Re: opening FC =0
    filled the pool yesterday, cleaned, vacuumed, and applied DE to filter today also too readings:
    The water looks cloudy and there was a lot of dirt on the bottom I closed it last winter and put a mesh cover over it.
    FC = 0
    pH = 7.2
    TA = 40
    CH = 160
    CYA = 40
    CC = 0.5
    TC = 0.5
    POOL TEMP 56
    This is my first time opening and I used the pool calc to come up with this:
    566 oz of bleach to shock at 15
    352 oz baking soda
    370 oz of calcium chloride
    I'm assuming that I should just run the shock procedure to completion and the worry about the other things
    does this all sou d about right? Any other suggestion are much appreciated as this is my first time-
    thanks
    38,295
    Re: opening FC =0
    I agree ... hit the bleach!!!
    When you finish the shock process, then maybe raise the TA and CH a little
    Herndon, Va
    65
    Re: opening FC =0
    I shocked the pool on Friday night. Saturday I cleaned it a couple of times, but my vacuum wasn't working very well. Today I found that the basket has a handle that has to be removed to get a good seal at the skimmer. After that it cleaned up well. I also found that I was loosing water out the filter/pool to drain. I tried taking the multiport valve apart a few times finally getting it to seal and then no more water being pumped out.
    Pool looks as good as it ever has. The FC is now 9.5 and CC is 0.
    I thought the FC would come down quicker especially since I pumped out about 2" worth of water over night.
    How long does the FC take to come down in a clean pool?
    Thanks for the help!
    Jim
    Re: opening FC =0
    With CYA around 40 you should be losing (very roughly) half of your chlorine each sunny day.
    Herndon, Va
    65
    Re: opening FC =0
    Thank you good to know this
