Thread: help keeping pool corner clean
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    197
    hey guys,
    I am having trouble keep a corner clean in the pool. Debris collects in the corner and wont move to the skimmer.
    The return/jet is 8" form the corner and I have the eyeball hitting the wall to the right and pushing water towards the skimmer.
    But that corner gets full of debris and seems to have a backwashing effect into that area. The nearest floor return is also aimed at that corner, but it does not help.
    Maybe a diagram of my pool might help. Maybe I need to move the eyeball in another direct? Other thoughts?
    The bold arrow shows were the debris gathers.
    thanks!
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: help keeping pool corner clean
    Are you getting circular flow in the pool? What direction is the jet at the lower left pointing?
    Apr 2010
    Coral Gables, FL
    197
    Quote Originally Posted by linen
    yesI think so.
    That one point pretty much straight with a slight bend towards the stairs. Also another return in the lower right, on the curve where the bench is. That point towards up pool looking at the photo. Towards the upper right corner.
