Results 1 to 20 of 20
Thread: Newish pool, cloudy water
    Cyclonic's Avatar
    Mar 2013
    South Africa
    45
    Since I'm new to proper testing (and not the eyeball test I've used for years ) and still finding my feet, what is the general consensus on cloudy water?
    My pool was renovated almost 8 weeks ago now.
    White marbellite was used.
    Municipal water was used to fill.
    Left for 21 days without using a pool cleaner.
    Up until Week 6 the water was crystal clear.
    First rain and the pool turned a pale green - shocked and blue again.
    Same story with second rain.
    Water cloudy ever since the first rain.
    Only chlorine used until now.
    Surface clean.
    Pool floor clean.
    First chemical tests:
    Chlorine < 0.1 ppm (I guess this is the biggest problem!)
    PH > 8.2
    Could not complete an acid demand test
    I decided to shock with chlorine until I get the pH right
    Care to hazard a guess as to how I end up resolving this?
    Re: Newish pool, cloudy water
    The very first thing to do, certainly before you shock, is to get the PH down to something more reasonable. PH should be between 7.2. and 7.8.
    Then, get a complete set of water test results. Ideally you should have your own top quality test kit. Nothing can save you money nearly as easily as knowing all of your water test numbers. Failing that, get test results from a pool store. Without test results it is impossible to say what might be going on.
    Cyclonic's Avatar
    Mar 2013
    South Africa
    45
    Forgot to mention I started Pool School as of 5 minutes ago.
    Lowering the pH...is that by adding acid? Regards the test kit, pool supplies here in S.A. are very monopolised. Pretty much all I've seen is this kit, which I bought:
    http://www.hth.co.za/index.php/hth-prod ... -equipment
    It's the top product of course. Is a 4-way test kit good enough? I've got a pool shop which does test water so that's another option, if I get stuck.
    38,299
    Yes ... keep reading:
    pool-school/pool_water_chemistry
    Cyclonic's Avatar
    Mar 2013
    South Africa
    45
    Very interestingly, I see our biggest brand here emanates from Atlanta. Who would've guessed? This is the product range I will use:
    http://www.hthpools.com/Docs/HTH_Pool_Care_Guide.pdf
    38,299
    The HTH test kit does not contain the most important test ... the FAS-DPD chlorine test. Best to order the K-2006 or the TF-100 online (see link in my signature for a comparison)
    Also, the values we recommend (pool-school/recommended_levels) may be different than what they are recommending. you have to decide which source of information you are going to trust as trying to mix the advice will lead to confusion.
    Cyclonic's Avatar
    Mar 2013
    South Africa
    45
    Hmm, is that not "Test" 1 where I used DPD tablets??
    No, the DPD chlorine test and FAS-DPD chlorine test are different. The DPD test measures FC and TC up to 5 (or perhaps 10) by variable steps, while the FAS-DPD chlorine test measures FC and CC up to 50 in steps of 0.5.
    Jun 2012
    Howell, NJ
    977
    You will definitely need a better test kit. We recommend either the K-2006 or TF-100 from tftestkits.net. Are you located in the US? I ask because I noticed the link to the HTH test kit had a different country code (.co.za) on the end. You are going to need to decide who's advice you are going to follow, because they will be different. To clear up the cloudiness, we are going to need to know FC level, CC level, and CYA level. Your current test, I believe, only gives TC levels, which is not enough.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Cyclonic's Avatar
    Mar 2013
    South Africa
    45
    @JasonLion: thanks for clarifying.
    @JohnN: Nope, I'm from South Africa.
    viewtopic.php?t=56805
    Let me dig around and see if I can get a better kit before ordering online. I don't even know if we have all the products that you guys would usually recommend.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    For the majority of issues we manage with basic items like bleach / liquid chlorine, baking soda, muriatic acid (hydrochloric acid), most of which can be found in a typical grocery or hardware store in the U.S. About the only pool only items we ever suggest are CYA stabilizer and perhaps a metal sequesterant if required.
    Cyclonic's Avatar
    Mar 2013
    South Africa
    45
    I'm pretty sure us saffers use pool-only products. I'm very interested in liquid bleach...I'm not sure they do it in bulk here so that it will be cost effective. Joining this board may turn out to be quite an eye opener for how we do pool care here.
    30,421
    It has been for thousands of others, cyclonic. Hope we can help you more. Welcome to the forum.
    Cyclonic's Avatar
    Mar 2013
    South Africa
    45
    If I heard of these methods from a neighbour or something, I would call it black magic ie. Edit: Deleted word. Butterfly
    Thanks for the welcome.
    Cyclonic's Avatar
    Mar 2013
    South Africa
    45
    I tested my water again but not too thrilled with how dodgy the results are. For the chlorine test, the DPD tablet for one is always crushed inside the foil; secondly it doesn't want to dissolve. So it "appears" that the levels are still < 0.1ppm - honestly I'm not sure though.
    For the acid demand test, pH is around 8'ish....table says I should add 375ml of acid but I will do that in the morning.
    Cyclonic's Avatar
    Mar 2013
    South Africa
    45
    Just a small update, due to the dodgy results from the HTH kit mentioned previously, I reverted to not testing at all. The pool remains crystal clear but may need some chemicals that I just won't know about without testing. I should pull up my socks!
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by Cyclonic
    I'd highly suggest getting a better test kit. What you propose is worse than using the pool store.
    Cyclonic's Avatar
    Mar 2013
    South Africa
    45
    You don't recommend pool store services?
    Smykowski's Avatar
    Sep 2011
    3,065
    Frankly no. 8 out of 10 times the pool store uses test strips, which are pretty much worthless, even if a computer is interpreting them. The 9th time they use a good drop kit, but the 16 yr old behind the counter doesn't care or isnt paying attention, so who knows if those tests are accurate. Maybe the 10th time out of 10 they do it correctly and you can trust the results.
    The second half of the problem is that most pool stores don't seem to understand the chemistry, specifically the CYA/FC relationship. They are simply dealers and follow the recommendations of their chemical distributors (who provide that fancy computer tester and also don't understand the chemistry or FC/CYA relationship).
    Hands down, the simplest, most cost effective way to care for pool is to do it yourself using the principles we teach on this site.
  20. Back To Top    #20
    Cyclonic's Avatar
    Mar 2013
    South Africa
    45
    I guess I'm going to be ordering a kit online then because the only kits around these parts are the rubbish ones I'm using.
