Thread: Pump not working on Low speed
    Aug 2010
    MA
    173
    2 speed Hayward pump with aqua plus controls going on its 3rd season. Opened pool 2 days ago and pump was operating fine. Ran the pool cleaner today on high speed for about 8 hrs. Went to kick the pump down to low for awhile and nothing. Tried several different times. Motor is not turning at all. Control panel display indicates that it thinks the pump is running. Any suggestions?
    Completed: June 2011
    18' X 38' IG Vinyl, 3' - 8' depth ~ 24K gallons
    2 skimmers, 2 wall suctions, 3 returns, 1.5" piping
    Hayward Equipment: 1HP Tri-star 2-speed, Aqua-Plus SWG,
    Star-Clear Plus 175 sqft cartridge filter, Colorlogic 4.0 LED
    The Pool Cleaner 4X(suction)
    2011 Jacuzzi J-280 Hot tub
    Re: Pump not working on Low speed
    The most likely possibility is a bad relay in the automation system. If you stand next to the power center box do you hear a click when switching between off and low? No click means it is almost certainly the relay.
    There are a couple of other possibilities, loose connection, bad motor winding, etc, but they are much less likely.
    Aug 2010
    MA
    173
    That's kind of what I figured. No click from the relay.
    Is this something I might be able to repair with the correct parts?
    Or perhaps a warranty repair? I believe because I purchased pump, filter and automation, I get 3 years from Hayward.
