Results 1 to 14 of 14
Thread: Water Testing
    Fields's Avatar
    Jan 2013
    Columbia, SC
    43
    Water Testing
    My pool hasn't been installed yet, but I want to test my fill water. I will be using tap water to fill the pool. My question is what should I test for, or do I test for everything? Thanks in advance for all responses.
    27x52 Garden Leisure AGP, Hayward Dream Line 1.5 Sand Filter, TF-100 Test kit
    BBB and Loving It!!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Water Testing
    I am assuming you have a proper test kit? Test...TA, ph, CH. Skip the cya test, there won't be any. Are you on city water? If yes, then you may get a measurable level of FC and CC, which is normal. Are you on a well? If yes, then you may want bring a sample to a store that can check for metals. Even when on city water your can still have metals present, so it might be good to check on that source too.
    Fields's Avatar
    Jan 2013
    Columbia, SC
    43
    Re: Water Testing
    Yes I have the TF-100 test kit. I'm on city water. Once I check the chlorine, will it indicate how much bleach I will need once the pool is filled? I will be using the BBB method, thanks to this great forum!!
    BBB and Loving It!!
    38,284
    Re: Water Testing
    You will need to learn to use the poolcalculator.com to determine how much of each chemical to add to acheive desired results.
    Fields's Avatar
    Jan 2013
    Columbia, SC
    43
    Re: Water Testing
    Ok, I just completed my first water testing, yayy me!! I did everything the instruction card said to do. Keep in mind my pool hasn't been installed, just testing the water and getting used to my TF-100 kit. Here are the numbers.
    FC= 5
    TC= 8.5
    TA= 40
    CH= 40
    I didn't do the CYA test.
    I hate to be a bother, but what exactly does this mean? I think it means that I won't have to add bleach. Help please. Oh and I used the Pool Calculator and it said to add 211 oz (weight) or 169 oz (volume) of baking soda and 489 oz (weight) or 390 oz (volume) of calcium chloride. Can someone explain this? Thanks.
    BBB and Loving It!!
    38,284
    Re: Water Testing
    Those are some surprisingly high FC and TC numbers for tap water ... these results seem suspect to me. Can you describe how you did the test?
    Your TA is a little low and the CH will be fine since you will have a vinyl liner.
    Did you do the pH test? Also do the yellow OTO test that is with the pH test and report those results.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Water Testing
    Quote Originally Posted by Fields
    FC= 5
    TC= 8.5
    TA= 40
    CH= 40
    Yowza! I bet that water tastes lousy with that much chlorine in it!
    You need to do the pH test as well. pH and TA are the critical ones to tell you how much acid or baking soda or borax you'll need to add. I'm guessing it's an above ground pool, so low CH doesn't really matter. That FC will be gone in one day as soon as the sun hits it, so prepare for that, too. Study Pool School and bookmark the pool calculator and you should be fine.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Water Testing
    FC= 5
    TC= 8.5
    TA= 40
    CH= 40
    No, you will have to add chlorine. The level in your city water will vary, and it will drop in your pool from various sources of demand. Organics and sunlight being the two primary causes of demand. Five PPM FC is really pretty high for drinking water, but that is the legal high limit in Texas. Likely where you are too.
    Essential Links:
    Fields's Avatar
    Jan 2013
    Columbia, SC
    43
    Re: Water Testing
    Quote Originally Posted by Richard320
    FC= 5
    TC= 8.5
    TA= 40
    CH= 40
    Honestly I don't drink the water! I may have done something wrong. I try it again later. Thanks for all of your help.
    BBB and Loving It!!
    30,419
    Re: Water Testing
    Report your pH and do the FC test once more. You likely had a testing error on the FC (that's common at first)
    Chlorine is a consumable item and will need to be constantly replenished in your pool.
    Your other parameters are fine for now.
    You are very wise to practice with the kit....you'll be an old pro by the time your pool is set up.
    It is very possible you may not need to add anything but CYA when you first fill. As you know, there is no need to test for CYA in your tap water because it has non.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,086
    Re: Water Testing
    How many drops did you use to turn the water clear on the FC test??
    38,284
    Re: Water Testing
    I would still like to see the result of the OTO test ... if that is nearly clear, then there was obviously a problem with the FAS-DPD test method.
    Fields's Avatar
    Jan 2013
    Columbia, SC
    43
    Re: Water Testing
    Ok I did the quick test and TC=3 and Ph= 8.2.
    BBB and Loving It!!
    30,419
    Re: Water Testing
    Lower you pH down around 7.4 with muriatic acid. That's the normal and you should never let it get above 7.8.
