Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Still green after 5 days
    wollerd's Avatar
    Dec 2012
    St. Louis, MO
    24
    I took the mesh cover off on April 4th and tested the water. Water level was below the skimmers but above the returns, clear but a lot of algae on the bottom and walls. Water temp was 55, FC=0, pH < 6.8, TA=20, CH=90, CYA=70. I got the water level up, circulating, in balance, and started the shock process. Iíve added liquid chlorine 12.5% using the chlorine/CYA chart and pool calculator at least twice a day (to the tune of 33 gallons). Testing prior to each 2nd daily dosing the FC=0 or slightly above and the CC was high (a good thing) until yesterday. At this moment the FC=11.5 and has been holding above 9 since last evening with minor adjustments to keep at shock level. Temp=62, pH=7.5, TA-120, CH=70, CYA=40. The water is still quite green and I donít think it has improved in color at all. Iíve brushed the pool on day 1 and again today. Of course, now I canít see the bottom or even a few inches into the water. Am I on track or am I missing something? Also, I see a lot of muck going into the skimmers but when I attempted to backwash today the sight glass ran clear from the beginning. I've got good circulation but not sure I'm filtering. Ideas?
    St. Louis, MO
    33K gal, IG vinyl, 2.2 SFHP WhisperFlo pump, Tagelus 325# TA-60D 3.1 sqft sand filter (24.5" diameter), MiniMax Plus 400M heater, TigerShark robot
    22,543
    Re: Still green after 5 days
    Is your multiport valve set on filter or recirc?
    What's your filter pressure running?
    24' x 52" Round AGP. 2hp/ľhp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Jul 2012
    Chicago, IL
    356
    Maybe I am misreading, but you also mention that your FC= 0 when you add your second daily dose of chlorine? You need to keep it at shock level throughout the process.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    wollerd's Avatar
    Dec 2012
    St. Louis, MO
    24
    Thanks for the reply, Bama Rambler, I'm filtering. The pressure gauge is broken and showing 0. I've ordered a new one which should arrive Friday. The returns are pushing a lot of water with nice pressure and the water is moving around the pool.
    Quote Originally Posted by Pauls234
    No Pauls234, you read this correctly. I've been checking/adding in the morning and again in the evening after I return from work. I understand that it needs to stay at shock levels but it depleted quickly and unfortunately, I couldn't babysit it 24/7. The FC is holding much better now but the pool remains green.
    St. Louis, MO
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Anything you can do to keep the level up at/slightly above your pools shocking FC level, will speed up the process. Over-shooting a little above the shock level can help it last longer, though I wouldn't make that standard process. The more you drop below your pools shock FC value, the longer it takes.
    Quote Originally Posted by wollerd
    When you are home, I would check every hour (until bed time) and redose appropriately. At least then you will be making hay while your there.
    Besides that you need POP (pool owner patience).
    wollerd's Avatar
    Dec 2012
    St. Louis, MO
    24
    Thank you linen,
    I've enlisted friends and family to watch over things while I'm out of the house. Shock level is 16ppm and I've only lost 2ppm in the last 4 hours. This is much better than the past few days. The CC is <1. Patience? {sigh} I'm working on it...
    St. Louis, MO
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It sounds like you are making good progress now that your FC is holding longer. Just remember, don't quit until you meet all three end of shocking criteria simultaneously (they are in my sig).
    wollerd's Avatar
    Dec 2012
    St. Louis, MO
    24
    I really don't see the progress any longer. My main issue at this time is the color/content of the water. This is my first year with the pool but I did see it in the late summer and it was clear. I've retested the CYA and I settled on the averaged high side at 50, FC is holding at 22 overnight, the CC is 0, and the temp is 62. The pictures below are from day 1, day 6, and day 7. I've put a lot of liquid chlorine in (36 gal) and expect to see gray or clear water by now. Thoughts or ideas? Thanks, as always!
    St. Louis, MO
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Can you see any debris on the bottom?
    Are you brushing regularly?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    You have it all but killed. It's that blue-gray color that shows the algae is dead or nearly so. brushing a couple of times a day or running your cleaner will speed things along a lot.
    wollerd's Avatar
    Dec 2012
    St. Louis, MO
    24
    Thanks for the quick responses. I have brushed but will increase frequency. I can't see the bottom but have run the Tigershark and it is picking up a lot of debris. So... my frustration is in vain? I'm still on the right track and brushing and running the cleaner should clear things up in the "near" future?
    St. Louis, MO
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Keep up the good work. I looked at green pool threads all last summer and the color change in your pics looks great for 1 week. After this year you might start thinking about keeping some chlorine in your pool to prevent all this work.....I haven't researched that so don't know what folks do about it now but years ago i maintained a concrete pool and they told me to just put a bucket of chlorine pucks in....that pool musta been loaded with CYA LOL.
    I wonder what dumping 2 gallons of bleach per week when your pool is closed would do?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jun 2011
    Long Beach, CA
    2,780
    If you can, net out the debris it will be much quicker than the cleaner. Are you able to check your filter pressure yet? Make sure you are still getting a good return flow and if it seems weaker at all, time to backwash the filter. It is improving and you should turn that corner soon, but you need to help it out as much as you can by brushing and removing the debris.
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by harleysilo
    Too much bleach with no mixing can damage a vinyl liner, so this isn't necessarily a good idea.
    Smykowski's Avatar
    Sep 2011
    3,065
    You are correct and on the right track. Remember that of the three, a sand filter will take the longest , but it will get the job done. Keep up the fight.
    Mar 2007
    San Rafael, CA USA
    12,082
    You might try Adding DE to a Sand Filter since I think your main problem at this point is circulation/filtration. I would generally recommend that when trying to clear any pool that uses a regular sand filter.
    wollerd's Avatar
    Dec 2012
    St. Louis, MO
    24
    Thank you all for the sage advice. Although there is a lot of muck on the pool floor I'm unable to scoop it out. The robot is doing a pretty good job but I'd say most of the problem is with the very fine particles in the water. I've read the DE article before and think that's a good idea. I'll get some in the morning.
    St. Louis, MO
    wollerd's Avatar
    Dec 2012
    St. Louis, MO
    24
    Day 12. I anticipated some improvement but really donít see much. Daily robot use is only picking up small amounts of dirt as expected and worms (rainy night). Still very cloudy and can't see the bottom. I think itís likely a filtration problem. I installed a new pressure gauge and the pressure has not risen until I added some DE. When I backwash I find the sight glass stays nearly clear. I visually inspected the sand in January digging down about two-three inches and found it clean without odor. No clumps. Channeling? I donít know. My numbers have looked great for 10 days. FC=20, CC=.5, pH=7.8, TA=130, CH=80, CYA=50. Any other ideas?
    St. Louis, MO
    30,408
    What size is your filter?
  20. Back To Top    #20
    wollerd's Avatar
    Dec 2012
    St. Louis, MO
    24
    325 lbs, 60 gpm. Strong flow from both returns.
    St. Louis, MO
