When did it make the sound? If the pump was on, you can not really have an air leak on the pressure side of the pump.
mpool said:I have been looking for a bigger filter and finding a sand filter that is 5.6 sqft is almost impossible. It would have to be around 34-36 in diameter. I saw the chart for filter in pool school maybe I will use a cartridge or DE. What is the recommendation of these types.
Be careful not to adjust ph when the FC is above 10 ppm. Ph will read high.mpool said:PH-7.2 (I added muriatic acid to bring it down from well above 8.0)
As for my CYA I added half the required 7 lbs 8 oz as per the pool calculator. I know it may take a week to register on a test, but should I add the other half? I put it in a sock in front of my return.
