Results 1 to 7 of 7
Thread: Pool draining
    Near Sacramento, CA
    47
    Pool draining
    Hi,
    My brother's pool has a high level of calcium. I told him he has to drain his pool, but he said that he needed to know whether there is water underneath the pool since it will cause the pool to push out of the ground. Do you know where he would find that information? He's looked online and even called the local water people, but to no avail. Thanks! He lives in LA, specifically in the Westlake, Agoura Hills, area.
    Outdoor IG Plaster Pool @18,000 gallons
    Cartridge Filter: Jandy CL580 (filter area 580 ft2, Max Flow 150 gpm, 6-hr capacity 54,000g)
    Pool Built est. 2002
    Dec 2012
    Manassas Park, VA
    207
    Re: Pool draining
    I have been going through the same thing in Virginia and have not been able to find any one that can tell me the water table in my area. Even though I was told someone in the Parks department should be able to tell me. However I do know that my pool has two hydrostatic plugs on the bottom and hopefully a hydrostatic valve in one of the main drains.
    My understanding is that I can drain the pool and still have some time (hours) once it is empty to get them open before the pool would be lifted if that was a possibility. I imagine that the higher the water table the less time I would have to open the plugs. However I have no strong evidence that this is the case. So out of precaution I am trying to do this after about 10 straight days of no rain in hopes that this will dry the ground enough if there is an issue with the water table.
    I have also been told that if the house has an inground basement that there should not be an issue with the water table unless the pool is deeper than the basement.
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    30,424
    Re: Pool draining
    Rahter than drain the entire pool, do so in increments of one foot or so if you are concerned about the water table.
    It DOES use more water but not as much as you might think if you do the math.
    Jul 2012
    SE Minnesota
    137
    Re: Pool draining
    How much water has to be replaced to reach your target number? If you can leave some water in the pool it may be a non issue.
    Just thinking out loud...a person can buy a post hole digger for about $20. If you dug a 6" dia hole as deep as your pool is and never encountered water, or let it sit like that for a day and water never seeped into the hole, would that indicate the water table is lower than your pool?
    Intex Ultra Frame 26'x52"
    Intex 2,500 gal/hr pump with Unicel cartridge filter.
    Re: Pool draining
    I live in Houston where we don't have basements because of the water table. I had to drain a lot of water to lower my cya from 200 to about 65. I was concerned about the water table. I was able to drain 14" without having any issues. I did about 5 drains overall, most about 6-7", but the big one was 14".
    19,500gal, Gunite, Pebbletec, Chlorine, PCC2000 cleaner, Stenner Chlorine Pump, MegaCatch Mosquito Trap
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: Pool draining
    It takes some hunting around, but it looks like the closest well that is monitored has never been less than 17 feet to water. http://www.water.ca.gov/waterdatalibrar ... 19W14K004S
    Here's the main map console. http://www.water.ca.gov/waterdatalibrary/
    In short, unlikely to float the pool.
    Near Sacramento, CA
    47
    Re: Pool draining
    Hey everyone, thanks for all the help. Ya, my pool is only around 7'-6" or so deep so I think I'm probably safe. I'll probably empty a little and see what happens and then keep emptying it out. I'll let you know what I find!
