Thread: Heat pump & Robotic cleaner- Return question
    Apr 2011
    Warner Robins, GA
    245
    I am installing a heat pump into my pool. A few questions in regards to the plumbing as at the same time I am moving to an electric cleaner.
    1. Should I leave the plumbing in place for the Polaris Boost Pump, Tees, and the flex hose? ( the though is if the robot goes bad I could have a plan b to run my Polaris) Or should I remove it for efficiency of the plumbing if any?
    2. Depending on the result of #1 above what should I do with the Quick connect in the pool wall for the Polaris? Leave it shooting water straight out, or somehow convert it to a return? I have two returns in the steps and two already in the pool.
    What are your thoughts?
    I am leaning towards leaving the plumbing but not sure if the quick connect shooting water straight out is disrupting my circular return motion.
    Thanks as always!!!!!
    Jim
    16 x 32 Grecian Vinyl. Salt-Aqua Plus PS-4, Hayward Pro Series Sand Filter, Hayward Ecostar SP34000vsp, Gulfstream HE-125-T-A Heat/Cool heat Pump
    22,553
    Re: Heat pump & Robotic cleaner- Return question
    I'd leave it in place. You can always bypass the pump and it magically becomes a return!
