Results 1 to 14 of 14
Thread: Landscape around Intex Pool?
    I'm putting up a 20' Intex round ultra frame this year, and just wondering what the consensus is for landscaping the rest of the bare dirt around the pool? I was thinking some stone, but I don't want the stone sitting directly against the wall of the pool. What options are there? Thanks.
    Intex Ultra Frame 18'x48"
    Intex 14-Inch Krystal Clear Sand Filter Pump
    Intex Intex Krystal Clear Salt System (not yet installed)
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Re: Landscape around Intex Pool?
    Depends on where you're located and how much you want to spend and maintain? Give us some details on your direction, low-ground cover, flowering, trees/bushes etc..
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    I want maintenance free. I'm actually in NY and my plan is to try and keep the pool up year round and just winterize it in the winter. And obviously don't want to spend much. Ideally just a border around the pool.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Sorry, cany help much with the cold-climate planting, I'm a SE Texas boy. However, I'm guessing the Juniper type ground cover would be hardy enough for cold climates (in well-drained soil). It's what I used for border planting (time will tell). I would start with that and make a trip to the local Garden Centers and confirm, then just pick some other ground cover/shrubs they have/recommend.
    Here are some good links; dont get your heart set on the ones they reference (not always feasible/available), but good reference for climate, draining, soild types, etc..
    http://www.landscape-design-advice.com/ ... signs.html
    http://www.gilbertaz.gov/water/popups/poolplants.cfm
    Junipers
    http://www.wilsonbroslandscape.com/Grou ... ipers.html
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I used cedar chips, they are super absorbant.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    I have trimmed the tarp and insulation down to abt 8" from the feet of the pool. Now I plan to wrap the vinyl baseboard (picture provided)around the legs and secure with zip ties. Once that is done I'll be making a concrete stone path around the pool. I purchased a mold and will use quickrete to build them.
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Oh, here's a pic of one of the concrete molds and what I was talking about.
    Angie M.
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    We did pea gravel with stepping stones. Works great! Left ours up over winter with no problem. Will be opening this weekend and setting up two solar heating panels!
    24' Sharkline Matrix. Coral Reef Liner. Clearwater II Cartridge Filter. Saltron Retro Salt WaterGenerator. 4x20 Ecosaver Solar Panels, Rover Jr. robot vac. Fiberglass Steps and Lifesaver pool fence/gate.
    Previous pool: 9x18 intex with salt water generator and vinylworks 5x10 deck.
    Where are you from Suzy? How did you winterize?
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    I'm in Hamilton NJ. We survived sandy too! If you search on my posts I loaded photos under another thread last year. It shows the landscaping we did
    We have a salt water pool. For closing I picked up a closing chemical kit and added that and ran filter for a day then emptied half of water. Dummy me forgot that just cuz you unplugged the pump doesn't mean you stopped the siphon. Poof empty pool! That was ok. Tho. We had a broken block under one of the legs so we fixed that ran to the pool store and grabbed another set of closing chemicals and filled the pool half way up again. About 4 inches below the lowest filter hole. We have a 9x18 ultra frame so I picked up 4 pillows that completely covered the surface and covered with an oval winter cover. It ended up being about even with the top frame. We did bungees and cement blocks all the way around the outside and picked up a cover pump that keeps water off the top of the cover. No issues at all. We had 11k in storm damage from down trees from sandy (we sit on a 50 ft bluff overlooking a park) and heavy winds and no issues whatsoever with leaving the pool up. I put the thermometer in a couple of weeks ago and Monday we were up to 57 degrees ANd crystal clear water. We're going to open this weekend, intex pools are much stronger than I expected. Sandy took 7 trees our front porch out big screen and our power but couldn't take out our 700 dollar practice pool. Go intex! Well upgrade to a permanent and larger pool when this one goes but I have no complaints at all regarding intex.
    Jul 2012
    San Diego, CA
    96
    We have a rectangular soft sided pool (the ones where the legs are u shaped and stick out from the pool at an angle). What we did was buy a reed privacy screen like this one http://www.lowes.com/pd_231190-80032...een&facetInfo= and wrap it around the sides of the pool. Then we put 3/4" gravel in front of that creating a patio style area in front of the pool. It looks really nice and hides the big blue pool. The reed screen has lasted 4 yrs, but I think we will finally replace it this year.
    NEW POOL : 9 x 18, 48" deep - Bestway brand, 1 HP Intex 3200 Pump/Sand Filter Combo, Wanda the Whale, Hayward through wall skimmer (still in box)
    OLD POOL 5,100 Gallons, 9 x 19 used Splash a Round, Intex SWG, 1.5 HP Hayward Power Flow LX pump, Pentair Clean and Clear 150 sq. ft. filter, hard plumbed, Wanda the Whale,
    Meganv,
    With wrapping the reed screen around the exterior of the pool. How did you attach it to the pool so it stayed in place?
    Lizzieann,
    27x54 AGP with Waterfall, 18,500 gallons, Waterway Sand filter- Waterway 1.5 hp -1 speed pump , TF-100 test kit, BBB method.
    Jul 2012
    San Diego, CA
    96
    Lizzieann,
    Because the pool legs are at an angle and the 3/4 rocks press against the bottom we have never had a problem of it shifting. But if we did my husband was going to use thin galvanized wire to attach the reed to the legs. If I can figure out how to attach a photo, I will load one up.
    Just an FYI. Big Lots is selling all outdoor "things" 75-90% off. I picked up enough landscape edging to go around my 20" round intex for under $20.00. It is the kind that comes in 4' lengths and you pound it into the ground with stakes already attached. I am excited as now I can actually weed wack next year instead of hand clipping
    ProSeries Above Ground 20x4 Sand filter 1 hp
