Results 1 to 10 of 10
Thread: What's my pool surface made of?
    Mar 2011
    Sacramento, CA
    7
    I've lived in my current house for three years and have an in ground pool. But I've never tried to figure out what the surface is (vinyl,fiberglass,concrete).
    I'll be moving to a new place in a couple weeks with an in ground pool and I'd like to figure out what that surface is made of too.
    Both pools are filled, is there a test or can it be determined by visual inspection and touch?
    Thanks!
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Re: What's my pool surface made of?
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    22,551
    It's pretty easy to determine the surface by look and touch. Pics will help as Pooly indicated.
    Mar 2011
    Sacramento, CA
    7
    Haha ok..
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    It looks like plaster to me, definitely not vinyl but I'm far from an expert. So maybe someone with high level pool surface knowledge will chime in
    22,551
    oh yeah, that's plaster.
    Mar 2011
    Sacramento, CA
    7
    Thanks the for help! My next battle is turning that new pool from a swamp back to a Pool (That pic above is about a year old, the pump has been broken for the last 6 months)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Do we know for sure that the new pool (the top pic I believe) is plaster? I agree the bottom pick (old pool) appears to be plaster.
    22,551
    Good point Linen. I suspect that it's plaster but a closer pic would be helpful. I was concentrating on the bottom one.
    Mar 2011
    Sacramento, CA
    7
    Won't have any better pics of the new pool until next week most likely. I'll update when I get some them.
