Thread: Pump lower than pool?
    Feb 2012
    Maryland
    400
    Will this be an issue? I want the pad to be on the outside of my patio behind the patio sitting wall. The area I want the pad is about 2 feet lower than the top of the pool. Will that be an issue for the pump?
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pump lower than pool?
    No, but you will want to add a cut off valve upstream from the pump so you can turn off water flow when clearing the pump strainer basket, etc. This is basically the way all pumps are on above ground pools.
    I have an in ground pool and my pump is below the water level, and I'm happy about this. I suspect that priming the pump could be troublesome if it were not below the water level.
    Austin, TX, 15,000 Gallon, Sand Filter, IG plaster, 8 Gallon Liquidator
    22,544
    When you get that valve Isaac mentioned make sure it's a full flow pool valve. Don't use a standard PVC valve. You want a valve on both suction and return lines.
    Feb 2012
    Maryland
    400
    Quote Originally Posted by Isaac-1
    Im going to have a 3-way on the input to the pump, one way from skimmer and one from main drain. I can close that off which should be ok correct?
    38,271
    Many valves have stops in place to prevent that actually ... so you do not starve the pump. But, they can be modified to allow it by removing the stops ... you just have to be careful not to turn the pump on with it closed.
    Posted from my Droid with Tapatalk ... sorry if my response is short
