Results 1 to 7 of 7
Thread: Trichlor
    Trichlor
    My residential pool has been having a lot of problems with calcium hardness and our water getting cloudy. We currently Cal-hypo briquette's and are considering switching to Trichlor. Has anyone tried tri-chlor?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Trichlor
    Welcome to tfp, bsap
    Just like the calcium buildup from using cal-hypo, Trichlor also has a similar problem in building up too much cyanuric acid (cya). I would suggest looking at pool school, maybe start with this article: http://www.troublefreepool.com/pool-..._chlorine_pool
    We likely can help you with your clouding, post a full set of test results! See: http://www.troublefreepool.com/pool-...efore_you_post
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: Trichlor
    Everything with pucks is a tradeoff. Calhypo---high calcium. Trichlor---------high CYA.
    Re: Trichlor
    So what would you recommend?
    38,301
    Re: Trichlor
    Liquid chlorine/bleach.
    See the link that linen posted.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    22,550
    Re: Trichlor
    Or an swg!
    I use bleach, but a lot of people have an swg. The best thing you can do right now is get yourself a good test kit and then post a full set of test results. That will tell us where you are and then we can recommend where you should be and how to get there.
    Jun 2012
    Howell, NJ
    977
    Re: Trichlor
    Yeah, bleach/liquid chlorine is the only source of chlorine that doesn't cause any side effects. In order to tell you why the water is cloudy, we will need a full set of test results. To test your water, you should get a TF-100 or K-2006 from tftestkits.net.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
