Thread: Jandy LXi heater has no power...
    I have a Jandy LXi heater. It trips the breaker when it is energized. When I pull the connector leeding from the power distribution board to the transformer it will not trip the breaker. Not sure if the problem is the power distribution board (no burn marks) or if the transformer is shorting (no outward signes of being bad) Suggestion?
    22,551
    Re: Jandy LXi heater has no power...
    You can check the transformer for a short with a multimeter or if you can disconnect the transformer from the board that may tell you which it is.
