Results 1 to 7 of 7
Thread: Bluish to greenish??
    Hi all and thanks for all of your help.
    I had my DE Filter broken down and cleaned a few weeks ago. :15 after the gentleman left my pool turned a greenish tint, (water still clear just greenish instead of blue). Am having a terrible time getting AND KEEPING it blue now. In the same day it will go blue then back to green. Can it have anything to do with that filter break down??
    Thanks
    Central Florida in-ground, 20,000 gallons, Size 60 DE Filter, diamond brite blue finish
    Winter Park FL
    10,000 gallons, 1.5hp pump, DE Filter, Marbletite Surface
    Re: Bluish to greenish??
    Did the color change happen shortly after you added chlorine (or any other chemical)?
    No after I had my DE filter cleaned.
    Winter Park FL
    22,553
    What you're describing sounds like metals in the water.
    Can you post a pic of it and post a set of test results and how you got them?
    Jun 2012
    Howell, NJ
    977
    Since you say it is clear, it sounds like metals. It could be copper, or most likely iron. The other possibility is algae, but that would be a clear green. What is your water source?
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Yes it is a clear green. I don't have the result numbers. I took a sample to Leslie's they said they thought it was metals too but it wasn't
    Winter Park FL
    22,553
    How did you/they decide that it wasn't metals?
    I say that to say this. Metals can be high enough to tint the water and not show up on most common tests.
