Results 1 to 20 of 20
Thread: Where is www.poolcalculator.com ?? It's gone
    Jul 2011
    Austin, Texas
    78
    It has been about 10 days since I used it, did I miss some big announcement??
    30K IG, Plaster with spillover spa, 9 ft deep end with spring base diving board
    48sqft DE Filter, 3HP VS motor, Hayward SPII, Raypak RP2100 Propane heater
    AutoPilot Pool Pilot Digital with SC-60 and pump relay (220v)
    Polaris 280. Pentiar Booster Pump, TF-100 Test Kit, Speed Stir
    Austin, Texas (It's hot)
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,109
    Re: Where is www.poolcalculator.com ?? It's gone
    Hey......where are you??
    Does anybody know the iphone app to use?? If that's still up that is.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    That happens every so often. Try the backup site. calc.html
    4knights's Avatar
    NE Kansas
    419
    Not sure why the pool calculator site isn't responding.
    The IPhone app is the second one in the apps store- I think it's called Psi flow technology.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    It's working for me, did you clear your cache?
    It is working just fine for me as well.
    38,520
    Yup. Fine for me.
    Jul 2011
    Austin, Texas
    78
    I went to it via the backup address and it worked fine.
    38,520
    The backup address is not really a "backup" it is a separate copy.
    Mar 2010
    Spring, TX
    1,082
    Has been working for me with no issues.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Aug 2010
    Columbia, SC
    96
    Is there an android app?
    20K Gal Blue Plaster IG with rock waterfall, Beach Entry, Hayward Goldline Pro Logic controller and SWG,
    Sta-Rite System 3 S7M400 cartridge filter, 1-1/2 HP pump, Energy Therm Heat Pump, Nexxus Savi LED lighting
    500 Gal Dynasty Miramax Fiberglass Cinema Spa
    38,520
    Quote Originally Posted by kgriggs
    Not from "poolcalculator" per se.
    SimplePool is developed by a member here as is Pool Pal I believe.
    carlos31820's Avatar
    Nov 2010
    Midland, Georgia
    353
    My vote for Simple Pool. Great app.
    16x36 Vinyl Pool - 22.5K gallons.
    Jandy Stealth 1hp pump - Jandy CS-150 filter
    Jandy Legacy 250k heater - Jandy Ei SWCG
    Jandy Watercolors LED light
    Paramount Vanquish in-floor cleaner
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Save that page as a local page on your computer and run it from there, that site is so valuable that I keep a copy backed up locally.
    Whoever maintains that page should invest in a PayPal donation link, I'd donate a few bucks!
    Jul 2011
    Austin, Texas
    78
    Darn good idea, Cramer. I just followed your suggestion. I'd be sooooo lost without that calculator!
    Jul 2011
    Eastern Ohio
    7,109
    Rather than donating, I paid for the app. Now of the site goes down I'm still good.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I saved the page locally on a couple of computers last year just in case it ever goes away and it is way to valuable to me to lose it. I like the paypal donation idea.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Is there an update for the iphone app? I don't know if it is only in my area, but I noticed that it seams the 6% bleach is being replaced with 8.25% concentrated, while the calculator on the PC version works great, and has the ability to manually input the percentage, the iphone app does not have this flexability and does not have a 8.25% option, only an 8% or 10%.
    22,300 gallon Inground Vinyl Liner pool
    Hayward DE 3620 filter Hayward Ecostar Variable Speed Pump
    1 Skimmer, 2 Main Drains, 2 Returns, 2 step Jets, 8 ft x 3ft waterfall
    38,520
    Unfortunately, it does not seem like the iphone app developer is very responsive to update needs ... neither is the website owner ...
  20. Back To Top    #20
    No, there isn't an update available, nor is one all that likely given their history.
    Just use 8% and don't worry about it. The actual percentage varies by more than 0.25% anyway.
