Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Hard plumbing intex 24' above ground pool
    I have just registered as a new member so please excuse if my questions seem like ones you have seen a dozen times.
    jsf0656 has a post and video on you tube of exactly what I am trying to accomplish by:
    Installing a Hayward through the wall skimmer
    Hard plumbing the entire system
    We have an Intex 24" AGP with intex sand filter and chlorine generator. When I look at earlier posts that say they contain parts lists and pics the images are no longer visable.
    Can someone please give me a parts list and step by step instructions to accomplish this conversion?
    Thank you.
    Re: Hard plumbing intex 24' above ground pool
    This is the most informative intex thread I've seen.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Thanks Speedo for the reply. I found that link earlier and my problem is the images are not showing when you click on any of the links.
    Yeah, that's a bummer. Did some of those links have part information? I think some might contain searchable information.
    Possibly others who have done the intex mods can re-post pics. Welcome to TFP.
    Aaron
    I think I found a great solution and it doesn't require any cutting or shaving. I found this at Home Depot in the sprinkler plumbing section. Its a 1 1/2" to 1 1/4" reducer. It fits perfectly in the plunger collars. You just have to ad a 1 1/2" coupler and you can plumb with 1 1/2" piping. I also found a 1 1/2" threaded male adapter that screws into the bottom of the Hayward skimmer. Here are pics. I'll post more when I get the pool up and everything connected.
    1) 7500 Gallon Free Form Gunite Pool / 800 Gallon Gunite Spa
    2) EasyTouch 8 Automation / IC20 Intellichlor
    3) Intelliflo VS Pump for pool and water features - Cartridge and DE Filter / 2 Speed Pentair Pump for Spa and Cartridge Filter
    None of the pictures I uploaded are showing up. If they aren't up tomorrow, I'll make a Youtube video.
    38,262
    How did you try to add the pics? I am guessing they were too big if you just tried to upload directly. Either make them smaller or upload to a photo-hosting website and link them that way.
    Hello can you provide the item number for Home Depot for the reducer?
    1) 20K gallons 2&5)Tagelus Sand Filter TA60D, 60 gallons/minute
    3inground 4)gunite
    6) installed 1984
    The receipt says PVC bushing SPGXS upc 049081133245. D2466 is etched on the bushing.
    Thanks I was able to find it Moines from the info you provided. Did you have any issues with leaking around the gray collar when the reducer is mounted to the equipment? I think intex makes the small black gaskets to insert prior to joining pipes to equipment. Did you use those?
    3inground 4)gunite
    6) installed 1984
    I'm not putting it together until this weekend. It shouldn't leak as long you keep the rubber gasket in place.
    Mar 2013
    Oklahoma
    25
    My son and I went looking for parts last night at Home Depot, specifically the reducer mentioned to attach to the threaded parts of Intex components. I ended up finding the box adapters at Lowes instead, and bought a 1.25" and 1.5" version of the grey box adapter. I saw in another thread where someone had used the 1.25" version, but it appeared to me that the 1.5" version was the better fit. On the parts that I found, I would've had to trim off the barbs and collar on the 1.25" adapter, but simply need to sand the top smooth on the 1.5" adapter.
    I got most of it together this morning. A lot easier than I thought. First I cut the gasket in half and siliconed each piece to the face plate and skimmer body to make sure it didn't move during installation. I then put the faceplate up to the liner and punched out the top screw holes and inserted the screws in to hold the plate in place while punching out the other holes. Then inserted the rest of the screws and attached the skimmer body. Then cut the liner and insert the flapper. With the piping, measure out the straight pipes before cutting and the dry fit everything. Then use a black marker the mark where everything joins. That way you know exactly how far the push in the pipes when gluing. The second set of plumbing is for a 2500gph pump I got on Ebay for $60. I'm going to use it to run a pool vac. I also found a set of pool lights at Walmart for $10. It's 2 lights with LED's and a remote and use a magnetic plate to stick to the liner.. I was expecting **** but they are really nice. They lit up the pool and half the yard. Here are the pics.
    http://s1284.photobucket.com/user/Vegas ... t=3&page=1
    22,544
    Good looking job!
    Nice job. But about the light make sure you check them every now and then cause the rubber sometimes leaks and causes the battery to leak. I have have the same lights and at 10 buck you can not go wrong.
    Intex Ultra Frame 14 x 42 3500 gals
    Intex SWG combo unit (2000 gph), screen door screening around cartridge:-).
    Had to vacuum the pool this morning because of a 2 day wind storm. The vac attachment for the skimmer worked perfectly and there's a lot more suction with the larger pipes. I was thinking about upgrading to the larger sand filter but I don't think I need to now.
    I checked the lights and one of them was full of water but it still worked. I'll put some silicone lube on the lid threads.
    Quote Originally Posted by VegasGMC
    Hello I am new to this web site and it looks like is what I am looking for, please forgive me if I make a mistake. I am getting the same pool 24 x 12 x 54" and I was looking at the same video I can put this together but like you I am stuck with the parts. I have also taken a look at the pictures in photo bucket my question for now is where can I get the grey adapter Home Depot or Lowes?
    18x36 Ingound vinyl Liner
    25000 gallons
    Jandy Stealth 2 speed pump
    Jandy 340 Cartridge Filter
    Jandy AE-TI 2500T Heat Pump 118000k btu
    Intermatic PE153 Digital
    Can you tell me where to find the grey collar?
    25000 gallons
  20. Back To Top    #20
    Apr 2012
    SW Ohio
    456
    I got mine at Lowes in the electrical dept, part number e996h
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
